Cutlass fuel pump to carburetor line
Old Aug 3, 2024 | 08:54 AM
Collegecutlass's Avatar
Hello,
I would like to replace the pump to carb hard line on my '65 Cutlass with a 330 and a four barrel carb. Every part supplier I've looked at including Fusick doesn't list a line for a '65, only '66 and on. Would a line for a '66 with a 330 work? Thanks in advance.
-RW
Old Aug 3, 2024 | 09:00 AM
Sugar Bear's Avatar
I don't think so, as I recall the 64 used a Rochester 4GC carburetor and the 66 was the first year of the Rochester Quadrajet.
Do you know what carburetor you currently have?
If you have the old line you should be able to reproduce it using it as a template. Steel line can be hard to bend on very short/tight bends, NiCop is a lot easier to bend.
Old Aug 3, 2024 | 09:19 AM
Jeff - Didn't Carter make many of the carburetors in 1965, as well?
Old Aug 3, 2024 | 09:21 AM
Sugar Bear's Avatar
I'm not sure about the '65 Carter builds. I've definitely seen and worked on Carter built Quadrajet models.
Old Aug 3, 2024 | 09:39 AM
I think maybe you're correct. I think '68 was the big year GM asked Carter to supply Quadrajet carburetors replacing "Quadrajet by Rochester” w/ “Quadrajet by Carter” instead. I do think they were identical.
Old Aug 3, 2024 | 09:53 AM
Rochester 4gc. Really my issue is the nut to the fuel filter etc is rounded off. Maybe I'll get the file out and try to salvage the current unit. Thanks fellas...
Old Aug 3, 2024 | 10:00 AM
... 1966 was first year of the Rochester Quadrajet on an Oldsmobile manifold I believe? I think the first year (1965) of the Rochester Quadrajet was only in the Chevrolet division.
Rallye469's Avatar
Inline Tube.
The 66 wont work as it's a quadrajet and not a 4GC
https://www.inlinetube.com/products/...OlrIKMRS3NmNlc
(gratuitous engine shot!)
Old Aug 3, 2024 | 10:04 AM
There's most likely some difference between the 400 & the 330 fuel pump>carburetor line but I would not know what, if any difference - perhaps they were same? At any rate, here's one for a 1965 400cid.
1965 Oldsmobile Cutlass 442 F-85 400CID 4bbl 3/8" Pump to Carb Line 1pc, Stainless
Old Aug 3, 2024 | 10:06 AM
Peter - You slid in front me.
Ugh...I'm slow today.
Old Aug 3, 2024 | 08:17 PM
The BBO is about one inch taller than the SBO from pan rail to carb flange. The 400 line won't work on a 330.
70sgeek
Sep 19, 2022 10:57 AM
old greybeard
May 14, 2021 04:29 AM
Daniel828
Nov 23, 2017 04:04 PM
35mastr
Nov 19, 2011 01:16 PM
boondocker
Aug 13, 2011 10:53 AM
