307 swap to older quadrajet and distributor
Old May 2, 2021 | 06:01 PM
deltsanddueces's Avatar
I have an 84 olds 98 and I got a carb from a 403 and a vacuum distributor I’m gonna swap onto it to not run off the ccc anymore. Can I leave all the rest of the emissions stuff alone for right now and just swap the carb and the distributor and still run?
I’m gonna be getting a b and m lock up kit for the trans
I also read on here that u have to rewire the a/c some how too
what exactly has to be don’t to retain the a/c?
Old May 2, 2021 | 06:47 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
I believe it is the ground for the relay or maybe the full throttle cut out switch, it has been a long time. The wiring in my 88 was a melted mess when I got it. Do you have cruise control? The ground wire to the speed sensor needs grounded for it to work as well.
Old May 2, 2021 | 07:10 PM
[QUOTE=olds 307 and 403;1339184]I believe it is the ground for the relay or maybe the full throttle cut out switch, it has been a long time. The wiring in my 88 was a melted mess when I got it. Do you have cruise control? The ground wire to the speed sensor needs grounded for it to work as well.[/QUOTE
Do I just splice into the ground wire on the compressor and ground it somewhere else or?
Old May 2, 2021 | 07:29 PM
I just cut the wire added a big ring terminal and grounded it to the big attaching bolt on the compressor. The grounds go through the ECM, once it is eliminated, you have an open circuit, which is why those wires need grounded. I asked that question, many years ago at Ford school when I was an apprentice.
Old May 5, 2021 | 08:16 PM
Oldcoyote's Avatar
I located that wire in the chassis service manual.
Old May 13, 2021 | 07:12 PM
If I leave the egr and the rest of the emissions stuff on there will I be ok?
im gonna start tearing into this this weekend
Old May 13, 2021 | 07:20 PM
Yes, there is still the specially timed port on the 70's Qjets. Pre 80 and Canadian cars used EGR without the CCC system.
Old May 14, 2021 | 03:35 PM
Cool thanks for your help
Skribble93
Jun 9, 2022 03:21 AM
Jes1984
Jul 21, 2020 05:14 AM
Copper Nine Eight
Sep 3, 2018 07:17 AM
Mark Mccrystal
Jun 25, 2018 07:54 AM
Viz G
Aug 6, 2009 04:02 PM
