Distributor replacement
Sep 2, 2018 | 04:33 PM
Copper Nine Eight
May 2015
Is there a distributor i can use to replace the one on my 307 but will also be able to swap into a mild built 403. Any help is appreciated.
Copper Nine Eight
Find More Posts by Copper Nine Eight
Sep 2, 2018 | 04:37 PM
oldcutlass
Oct 2009
Poteau, Ok
Any distributor that fits the 307 non CCC will fit the 403.
oldcutlass
Find More Posts by oldcutlass
Sep 3, 2018 | 07:17 AM
joe_padavano
Mar 2007
Northern VA
Quote:
Originally Posted by
WB8588
I ASSUME you are running the 307 off the computer, so you have a non-electronic carb as well?
joe_padavano
Find More Posts by joe_padavano
Looking for Christopher from Performace 307
Andrew1980
06:44 PM
Replacing and Olds 307 with 350 or 403
rpjr42
07:47 AM
307 timing??
iamjcoahran
Sep 4, 2014
11:52 PM
Need an HEI distributor with VAC ADV for S.B.O.
msouders88
09:57 AM
307 to 403 swap?
87customcruiser
07:05 AM
1970 cutlass horn relay
07:39 PM
