Pushrod length
Old July 29th, 2019, 12:31 PM
Branch Travis's Avatar
Pushrod length
Hello everyone, im new to the group and like you i am a lover of the olds, specificly the 81-86 cutlass supreme. I have a question that im hoping someone can give me the answer too. I took my 350 rocket and bored it over 30 shaved the heads and did a 3angle job on the valves. I also installed a 490 lift comp cam etc. etc. ,which brings me to my question. Can anyone tell me what would be the proper lenght pushrod i should use?
Branch Travis is offline
Old July 29th, 2019, 12:34 PM
You need to use an adjustable push rod to determine the correct length. Use the adjustable rod to get the valve train geometry right, then measure the length of the push rod and order a set in that length.
Fun71 is offline
Old July 29th, 2019, 01:40 PM
69455's Avatar
www.youtube.com/watch?v=o5is9BsH5OU
69455 is offline
Old July 30th, 2019, 12:53 PM
Schurkey's Avatar
No, although some folks might take a guess at it.
1. You MUST measure pushrod length for the engine in question. There are a dozen variables that can affect pushrod length.
2. If you're using the stock rocker arms with the bolt-down fulcrums, pushrod length affects ONLY the lifter preload. Not nearly as critical a dimension as with an adjustable valvetrain where it also affects rocker arm-to-valve tip geometry.
3. When you measure the pushrod length, be aware that there are AT LEAST three different ways to measure, and you need to use the same measurement that your pushrod supplier is using.
Schurkey is offline
mazey
October 10th, 2017 03:21 PM
boese1978
July 22nd, 2017 04:12 PM
boese1978
March 10th, 2015 03:06 PM
LX89mustang
September 27th, 2012 07:27 AM
MY71CUTLASS
October 4th, 2007 12:21 PM
Quick Reply: Pushrod length
