SB 5 Main Halo
Old Oct 12, 2022 | 03:43 PM
cutlassefi's Avatar
SB 5 Main Halo
Here are the specs and a couple pics of my 5 main halos for small block Olds;
1018 Steel
All sides CNC’d
Approx .400 thick
These were test fit on a about a half dozen blocks, a couple of 403’s and the rest 350’s. We found an inconsistency in the alignment of the main saddles, most notably #4 main. Because of that they don’t fit as well there as I would like them to. But with good studs and proper machining these should still offer a stiffening of the main saddles. In addition these will be significantly flatter than the previous J&S halos.
Cost is $365.00 (halo only) plus the ride.
Old Oct 12, 2022 | 04:14 PM
rickw30's Avatar
My J & S Halo is perfectly flat. Fitment was perfect and only cost $250.
Old Oct 12, 2022 | 04:34 PM
cutlassefi's Avatar
Very good.
Old Oct 13, 2022 | 10:17 PM
Bernhard's Avatar
Looks like a nice piece do you make one for the big block?
What is the reason for the minor fitment issues that you are having?
Thanks for posting
Old Oct 14, 2022 | 04:57 AM
cutlassefi's Avatar
Thanks for posting
This one can be modified to fit a big block. However because it’s thicker than most bb halos, you’ll need to trim it in order for the pan to fit well.
As stated the bolt holes are a bit of a compromise because of the inconsistencies of the main saddles block to block. In order for it to fit everything, the bolt holes are a bit larger than snug.
Noodles66442
Aug 6, 2025 04:05 PM
Battenrunner
Oct 13, 2018 04:56 AM
madmax442
Apr 6, 2018 10:17 PM
70442rag
May 9, 2017 07:09 PM
