Well it happened
Old Oct 16, 2022 | 04:15 PM
coppercutlass's Avatar
Chevy budget Olds powered
Well it happened
Clicked off an 11.49 with a 1.54 60 ft. @ 113.60 mph . Those who know ., know this is just a pump gas iron headed .030 350 olds. This was its final send off. Time to pull it out and freshen it up. The last engine i built was at the peak of covid. and when i freshen this engine up well there is a high possibility of an overbore and new rods. Are the SBO rods still available ( cutlassEFI) i need an excuse to go to florida this is your call lol. and at that point i would do 4.100 piston that I believe he also offers and a solid roller cam. The master cylinder head guru cutlassfreak who did my heads will be doing bigger valves and a little more port work. The back up engine will be going in over the next week and then hitting the track to see how that does and thats a 355 ported J headed engine with a solid engle cam and RPM intake., Should be fun to see what it does. Its been a while but i been bracket racing the car alot but im still pushing forward with the low buck sbo stuff i normally do.
here is a link to my youtube . more of a vlog but there is an in car video there., but you can go back and see the back up engine and prior runs ??? if you care to.
Old Oct 16, 2022 | 05:04 PM
Oldsguy's Avatar
Past Administrator
Congrats on the accomplishment
Old Oct 16, 2022 | 05:28 PM
2blu442's Avatar
Yes, that's pretty cool!
Old Oct 16, 2022 | 05:45 PM
HighwayStar 442's Avatar
Great Copper! I alway enjoy your threads. Bigger valves and a little more port work, always works wonders! Have cutlassfreak go full out on the porting. I am sure you will not be sorry. What size intakes valves? 2.07
Did I see right? You went to RPM to 7200 - 7300?
Old Oct 16, 2022 | 05:53 PM
Yes it clipped 7300 ish . I set the shift light to 6700 but today since I was after E/T I was shifting by feel and ear and would shift when I would feel the RPM start to want to plateau and it would hit at that rpm.
Old Oct 16, 2022 | 06:19 PM
oldsmoboogie's Avatar
Congratulations!
Old Oct 16, 2022 | 06:22 PM
SBO can have great torque and HP. Up in that range with the right combo. I go to 6500 sometimes, but have no arp hardware. Other than head bolts.
I keep thinking a D or DX block, would be in your future. .
Old Oct 16, 2022 | 06:33 PM
VORTECPRO's Avatar
Very nice! And congratulations to Cutlass freak as well.
Old Oct 16, 2022 | 06:35 PM
The short block has ARP rod, main and head bolts. No studs on this engine.
Old Oct 16, 2022 | 07:06 PM
Bernhard's Avatar
Awesome congrats on the new PR.
Old Oct 17, 2022 | 05:38 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Congratulations! Yeah, the Mahle pistons in 4.100" are available along with the Molnar rods. They are a 10cc dish in a 4032 material. Mahle recommends .0035" piston to wall for racing applications, an extra .0010" of clearance.
Old Oct 17, 2022 | 01:37 PM
Greasly's Avatar
If the motor is in good condition it might make economic sense to leave it together. Or leave the short block together. Particularly if you intend to go with a larger bore and aftermarket rods. Pick up a good core that only has grocery getter miles on it. Maybe you already have one. Maybe offset a 330 crank? Or skip the cost of the solid roller and do a 4" stroke short block solid flat tappet. Not sure if that would mesh better with your gears and converter. Solid roller costs add up quick. Just a thought. Good luck.
Old Oct 17, 2022 | 03:25 PM
We will see how well the internals look but for as hard as I have ran the car at minimum it needs rods lol. It's got over 200 passes and 3k street miles all of them hard. I'm sure the stock rods are ready for retirement
Old Oct 17, 2022 | 03:45 PM
cutlassefi's Avatar
As Christian said, 4.100 Mahles are available.
As far as rods go you have 2 choices, Scat or Molnar. The Scats are in stock but aren’t centered like an Olds, but they’re still a cut above stock, and lighter.
The Molnars are better out of the box but won’t be available for another 6 weeks or so according to Tom Molnar.
Hope this helps.
Old Oct 17, 2022 | 03:58 PM
I probably won't be digging into this engine for a few more weeks. I'm in no rush I'd prefer the Molnar rod. Shoot me a price for the pistons and rods . I know prices have probably gone up since we spoke
Old Oct 17, 2022 | 06:09 PM
VORTECPRO's Avatar
I think you should look at the converter, seems like a lot of slip in high gear, you might be quicker than you think. But then again when I look at the numbers they make sense, I've just never seen a 10 inch converter get it done. What was your 330 foot?
Old Oct 17, 2022 | 06:19 PM
330 is 4.60
Old Oct 18, 2022 | 05:13 AM
83hurstguy's Avatar
Congrats! Glad to see all the hard work pay off.
Old Oct 18, 2022 | 06:52 AM
anoldsman's Avatar
Awesome run!
Old Oct 18, 2022 | 07:58 AM
68post's Avatar
Congrats on a new PB. Great to see it getting done with a gas smallblock, the most underutilized platform with a lot of potential.
Old Oct 18, 2022 | 08:44 AM
That's been my mission. To prove the SBO is just as capable and more durable.
Old Oct 18, 2022 | 09:19 AM
fleming442's Avatar
Oh, you're doing that in spades, man! Congrats, again!
Old Oct 18, 2022 | 03:26 PM
CANADIANOLDS's Avatar
I missed it,, what happened?
Old Oct 18, 2022 | 04:57 PM
You sure missed it 🤣
Gerald Nickels
Apr 27, 2020 12:38 PM
coppercutlass
Mar 9, 2018 12:52 PM
thatguy32567
Aug 18, 2016 09:18 PM
edfiero
Feb 27, 2016 07:20 AM
oldcutlass
Mar 25, 2014 04:20 PM
