Cometic MLS for 455 with 1/2" head bolts?
Old Apr 5, 2020 | 06:36 AM
Saresks's Avatar
Hi,
if somebody has experience,
I'm planning to get Cometic MLS head gaskets C5811-036 advertised for 455 engine, and using them in small block, heads and threads converted for 1/2" head studs. How tight are Cometics bolt holes? Any problems with that?
Thank you,
Sami
Old Apr 5, 2020 | 08:42 AM
svnt442's Avatar
Originally Posted by Saresks
Hi,
Thank you,
Sami
The same gaskets are listed for the 1977 350 that came with ½" bolts, so you should be just fine.
Old Apr 5, 2020 | 08:55 AM
Saresks's Avatar
Great, thanks a lot!
Old Apr 6, 2020 | 06:00 AM
Run to Rund's Avatar
I just checked a Cometic .027" big block Olds head gasket. It has plenty of clearance for 1/2 inch head bolts, and comes with the alignment tabs for both BBO and SBO.
Old Apr 6, 2020 | 06:50 AM
oddball's Avatar
Yup, I've used a few different cometic patterns (the first chunk of their part number is the pattern). All are set up for 1/2" bolts.
ohiocutlassparts
Jan 15, 2014 04:36 PM
taa442
Jun 22, 2012 01:08 AM
boondocker
Jun 18, 2011 12:29 PM
greenslade
Jan 27, 2010 06:42 AM
dman0712
Dec 11, 2009 07:33 PM
