455 head bolts
Old Jun 8, 2012 | 11:29 AM
taa442's Avatar
455 head bolts
Hi, I took apart the engine out of my 70 Cutlass sx some time ago and I can not remember where the head bolts that have the fine threaded studs on top go.My car has ac,pwr steering.I also have three of these type of head bolts.Does anyone have an idea where these are placed?Thanks,Tim
Old Jun 8, 2012 | 11:41 AM
taa442's Avatar
455 head bolts
Hi,I took apart my 455 engine sometime ago and I can not remember where the fine studded top portion head bolts go.It is a70 455 Cutlass SX with ac,pwr steering.There are three of these type of bolts.Any ideas where they go?Thanks,Tim
Old Jun 8, 2012 | 06:19 PM
Octania's Avatar
Three? Hmmm...
Lower set of bolts, first one back that's not the short one, i believe.
The 3rd.. not sure. Anywhere except under the rocker covers I guess.
Generally only the RH head unit gets used, for a beasty AC bracket, at least on the A-bodys.
Old Jun 22, 2012 | 01:04 AM
ah64pilot's Avatar
I know this is a little late but for anyone else:
Driver's side: bottom row, #2 hole from the front
Passenger's side: bottom row, #2 & #3 from the front
Old Jun 22, 2012 | 01:08 AM
ah64pilot's Avatar
Passenger's side: bottom row, #2 & #3 from the front (IIRC 3rd bolt at center exhaust port is used to support the heat riser)
stanzaschance
Jul 28, 2015 06:38 AM
nolabigdawg
Oct 25, 2014 11:50 AM
Olds Scott
May 29, 2013 08:15 PM
Oldssupreme
Feb 6, 2013 12:39 AM
GTA_doum
May 18, 2012 02:36 AM
