455 tear down
Old Jan 25, 2010 | 04:13 PM
greenslade's Avatar
455 tear down
Just started to remove eng from a 73/98 when removing the ac compressor bracket the bolts at the head started to turn I believe that thay are head bolts,I was not planning to remove the heads,was going to replace rest of gaskets and paint engine should I just retoqure the bolts or am I asking for trouble later on? Can any recomend a good gasket set?
Old Jan 25, 2010 | 04:31 PM
The head bolts hold only the heads on to the block. Any accessory brackets will use other bolts. Any auto repair manual should show you wher the head bolts are, like Chiltons, Motor, etc. if you do not have any Olds service manuals.
Old Jan 25, 2010 | 04:42 PM
svnt442's Avatar
There are two or three head bolts (one on the drivers side and one or two {I can't remember for the A/C} on the passengers side) that have studs on top of them for both the A/C and the alternator.
If your head bolt loosened up while trying to remove the nut that holds the bracket on then either that thing was RUSTY or the bolt needed attention anyhow.
It couldn't hurt to re-torque all of the head bolts just to be on the safe side. Seeing that this engine is 37 years old it can't hurt.
Old Jan 25, 2010 | 05:12 PM
greenslade's Avatar
No I don,t have any manuels yet! when all esle fails I'll read the instructions.
the bolt are on the right side I,ll take them out and have a look for rust,then check the holes for coolant.kind of concerned about blowing a gasket after I re install the engine.
Thanks,
Old Jan 25, 2010 | 05:23 PM
citcapp's Avatar
Here are the torque spec's http://www.442.com/tech/torque.html
Just re-torque them. If you loosen them all then you had better replace the gaskets.
Old Jan 25, 2010 | 05:44 PM
jensenracing77's Avatar
if it was just one bolt i would just re torque it. i don't think it would hurt anything. i would at least replace the freeze plugs before you put it in another car. especially the one behind the head.
Old Jan 25, 2010 | 05:49 PM
greenslade's Avatar
Thanks,citcapp added that site to favorites.I plan to replaces other gaskets and all freeze plugs plus rear main seal
thanks to all
Nelson
Old Jan 25, 2010 | 08:30 PM
64Rocket's Avatar
Seeing as the engine is 37 years old and the factory steel shim head gaskets tend to rust out. It would be a great idea to replace the head gaskets. You also have to pull the pan and remove the rear main cap and at least loosen the other four main caps in order to lift the crank to get to the rear main seal. Be sure to hot tank the oil pan.
If you use the Fel-pro head gaskets, I would mill the heads at least .030 to make up for the thickness of the new head gasket. that should bring you back to the factory compression. While you are there, do the timing chain and a new oil pump. Be sure to shim the spring on the new oil for a little extra measure.
Just a couple of thoughts I had while you have the engine on the engine stand.
Gene
Old Jan 26, 2010 | 05:37 PM
greenslade's Avatar
455 tear down pics
Here are a few pictures of my toy 73/98
Old Jan 26, 2010 | 05:42 PM
greenslade's Avatar
and a few more
new to this computer stuff,hope restoring the car is easier lol
Old Jan 27, 2010 | 06:42 AM
Cool car! It is definitely red!
Stevec
Mar 24, 2012 10:18 AM
sunsetlimited
Jul 13, 2011 10:01 PM
rocket1889
Feb 24, 2011 08:08 PM
oldsonharmont
Jun 8, 2010 08:45 PM
bigde53
Mar 23, 2009 07:37 AM
