Carb spacer dyno test
Old October 25th, 2012 | 09:07 PM
VORTECPRO's Avatar
A few weeks back I promised a carb spacer test along with a water temp test. Performer RPM air gap, 770 CFM holley carb which pulled 2.4 inches of vacuum @ wide open throttle, the spacers tested were 1 inch 4 hole, and a 1 open spacer. Water temp tests were done at 133 degrees and 158 degrees.
Old October 25th, 2012 | 09:08 PM
VORTECPRO's Avatar
Old October 27th, 2012 | 10:00 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
What's with the folded pages?
Old October 27th, 2012 | 10:36 AM
TripDeuces's Avatar
Why is it so lean? You're going to burn a piston if you keep that up. It's more lean when the temp is lower.
Old October 27th, 2012 | 05:17 PM
VORTECPRO's Avatar
Measured or observed or in the room HP/TQ under the fold.
VORTECPRO
January 29th, 2018 06:39 AM
shamusj
March 4th, 2016 07:48 AM
VORTECPRO
Non-Olds Engines
17
October 14th, 2012 06:46 AM
IB Adrian
September 12th, 2009 01:43 PM
65Delta88
March 25th, 2008 08:18 AM
