Carb spacer dyno test
Old Oct 25, 2012 | 08:07 PM
VORTECPRO's Avatar
A few weeks back I promised a carb spacer test along with a water temp test. Performer RPM air gap, 770 CFM holley carb which pulled 2.4 inches of vacuum @ wide open throttle, the spacers tested were 1 inch 4 hole, and a 1 open spacer. Water temp tests were done at 133 degrees and 158 degrees.
Old Oct 25, 2012 | 08:08 PM
VORTECPRO's Avatar
Old Oct 27, 2012 | 09:00 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
What's with the folded pages?
Old Oct 27, 2012 | 09:36 AM
TripDeuces's Avatar
Why is it so lean? You're going to burn a piston if you keep that up. It's more lean when the temp is lower.
Old Oct 27, 2012 | 04:17 PM
VORTECPRO's Avatar
Measured or observed or in the room HP/TQ under the fold.
VORTECPRO
Jan 29, 2018 05:39 AM
shamusj
Mar 4, 2016 06:48 AM
VORTECPRO
Non-Olds Engines
17
Oct 14, 2012 05:46 AM
IB Adrian
Sep 12, 2009 12:43 PM
65Delta88
Mar 25, 2008 07:18 AM
