400 pistons.
Old Jun 1, 2012 | 01:46 PM
Stevec's Avatar
400 pistons.
Does anyone know where to buy a set of .30 or .60 over pistons for a 400 engine?
Thanks.
Steve...
Old Jun 1, 2012 | 03:46 PM
allyolds68's Avatar
Thumbs up
Check Kanter, They used to list them.
I thought you decided to go with the 455
edit: I just looked at Kanter and they list pistons for a 65-69 400......bullsh!t. They used to list 68-69.....
Old Jun 1, 2012 | 03:53 PM
Stevec's Avatar
Well I rebuilt the top end of the 400 and I'm just pricing out some parts for a future (2 years from now) total build. Who knows maybe I will do a 455 but I like having a numbers matching car to.
Decisions decisions...
Old Jun 1, 2012 | 05:27 PM
2blu442's Avatar
Egge has pistons. Here's a link to their web site:
http://www.egge.com/site/?d=48&dt=1&...SMOBILE&rpp=10
Old Jun 1, 2012 | 05:29 PM
Stevec's Avatar
I'll check em out! Thanks guys..
Steve.
Old Jun 1, 2012 | 05:49 PM
Octania's Avatar
0.300 or 0.600" is one hell of an overbore!
perhaps you meant 0.030-0.060"
Old Jun 1, 2012 | 06:17 PM
aliensatemybuick's Avatar
"me somebody" site member
Of course the guys who like to point out spelling errors would never have caught that; we all knew what he meant though.
Old Jun 2, 2012 | 02:34 AM
ah64pilot's Avatar
Perhaps this should be in the big block section...it might get more exposure.
Old Jun 2, 2012 | 06:19 AM
cutlassefi's Avatar
True.
But how about we step out of the box;
68-69 400/455 Olds crank, 4.25 stroke
65-67 400/425 Olds Rod, 7.00in length
Keith Black Icon IC846 Mopar piston, 1.465 comp distance.
2.125(half the stroke)+7.00+1.465+10.590. Stock deck height is around 10.625, you can cut the deck if you like. Just an fyi, the popular combination in a 455 of the L2323 piston, stock rod and crank comes in at 10.595.
IC846 Piston is 3.910 std bore available in std., .030, .040, .060 over with a .984 pin. You can hone the Olds rod (.980) .004 to fit or bush it for the .984 pin. Plus that .984 pin is much lighter than the Olds/Pontiac .980 pin.
Compression would be around 9.75-10.0:1 depending on deck height etc.
Problem solved, and with a much better piston with a much better ring pack. If the walls are thick enough you could also use the IC744 with a 4.00 bore. Compression distance and pin size are the same as the IC846.
Jmo.
Old Jun 2, 2012 | 10:40 AM
501Paratrooper's Avatar
I used Egge. They messed one of them up and was a bit of a pain to get them to replace it. But they did come through eventually.
Old Jun 3, 2012 | 09:22 PM
64Rocket's Avatar
Mark,
Nice combo with the 4" piston and the 4.25 stroke, nice 427 cid.
Gene
Old Jun 4, 2012 | 09:16 AM
Stevec's Avatar
Hey Mark what would you rate something like that as far as power? have you done it
before? That sounds like a great engine..
Old Jun 4, 2012 | 11:29 AM
cutlassefi's Avatar
No haven't done it but I'm all about trying different combinations.
I would say apples to apples the overbore to 4.00 would probably get you another 30-40hp/tq.
But that would open up the possibility of a larger cam, carb etc. And the insides would be a bunch lighter, that's always a good thing.
getawaycar
Jul 13, 2011 05:13 AM
madwagon56
Jun 17, 2011 05:11 AM
66-3X2 442
Jan 19, 2011 12:14 PM
501Paratrooper
Aug 31, 2010 03:51 PM
69442
Aug 6, 2010 05:03 AM
