1968 442 Air Cleaner
Old March 17th, 2019, 05:21 PM
1968 442 Convertible
bry593's Avatar
Turns out, I've got a real dandy 1969 big block air cleaner. Unfortunately, my car is a '68 and so has valve cover breather on driver's side. Willing to trade plus cash, or buy outright if not a crazy price. I'd even go for just the base. Worst comes to worst, I'll convert to 1969 valve cover breather and grommet.
bry593 is offline
Old March 17th, 2019, 06:32 PM
Yellowstatue's Avatar
As referenced in your other post, that OS air cleaner is a '69.
Yellowstatue is offline
Old March 17th, 2019, 07:09 PM
bry593's Avatar
'69 Vista?
bry593 is offline
Old March 17th, 2019, 09:20 PM
It doesn't matter. All 4 bbl 400 Vista & 442 used the same breather, different label > #624835 & 6424958 for W30, 1968.
Old March 18th, 2019, 02:39 AM
jollyolds's Avatar
pm sent
jollyolds is offline
Old March 19th, 2019, 02:50 PM
1slowbird's Avatar
I have a 6424834 or air cleaner in the garage. I dont know if it'll work for you. I have no use for it. Let me know and I'll get some more pics later this evening.
1slowbird is offline
Old March 19th, 2019, 07:35 PM
OE is a small block.
Old March 20th, 2019, 07:38 AM
bry593's Avatar
Yellowstatue, is the small block base physically different with regard to the valve cover tube location? I’m not worried about the stove pipe since my manifold tins are gone. My primary focus is getting my covers valve covers hooked up properly.
bry593 is offline
Old March 20th, 2019, 09:02 AM
allyolds68's Avatar
The snout opening is smaller
allyolds68 is offline
Old March 20th, 2019, 10:55 AM
bry593's Avatar
Slowbird sent me pics and is similar to the 1968 big block base except the snorkel doesn't taper. Might even be a bit longer as well.
bry593 is offline
Old March 20th, 2019, 11:13 AM
allyolds68's Avatar
I'm not sure what you mean. An OG air cleaner snout tapers, just not as much
OG:
https://classicoldsmobile.com/forums/parts-sale/96733-1968-olds-442-air-cleaner-og.html#&gid=1&pid=2
OE:
https://classicoldsmobile.com/forums...r-cleaner.html
Old March 20th, 2019, 12:55 PM
bry593's Avatar
Slowbird's air cleaner was for a small block. It looks much the same as a big block base, except the snorkel is not tapered.
http://i7.photobucket.com/albums/y27...psjdfwkqsc.jpg
bry593 is offline
Old March 20th, 2019, 01:38 PM
allyolds68's Avatar
That doesn’t even look like a 68 air cleaner
The two links to “for sale” posts I posted above are the correct air cleaners bases for the 68’s. There are other variations but other than the OAI and the 2 bbl, the only difference is in the cover stickers
Old March 20th, 2019, 02:11 PM
1slowbird's Avatar
This is what it says on the side of the air cleaner base.
Old March 20th, 2019, 04:00 PM
rocwal's Avatar
^8 air cleaner
I have an air cleaner off a 68 Olds 98 with 455 , 4 Bbl carb if this is what you want let me know . I can send you pictures and price
rocwal
Dan B
rocwal is offline
Old March 20th, 2019, 04:29 PM
bry593's Avatar
rocwal
Dan B
Thanks Dan. I am interested. I sent you a pm with my phone number for text of pics.
bry593 is offline
Old March 20th, 2019, 07:21 PM
The small block snorkel has a welded piece at the opening of the snorkel and is smaller. The big block snorkel is wider at the opening and no extra metal.
arcticman
January 20th, 2019 02:20 PM
66-3X2 442
September 27th, 2012 01:23 PM
arodenhiser
June 23rd, 2010 12:16 PM
grt05
November 3rd, 2009 02:30 PM
dan1s
March 13th, 2008 10:38 AM
Quick Reply: 1968 442 Air Cleaner
