1968 442 Air Cleaner
Old Mar 17, 2019 | 05:21 PM
bry593's Avatar
1968 442 Convertible
Turns out, I've got a real dandy 1969 big block air cleaner. Unfortunately, my car is a '68 and so has valve cover breather on driver's side. Willing to trade plus cash, or buy outright if not a crazy price. I'd even go for just the base. Worst comes to worst, I'll convert to 1969 valve cover breather and grommet.
Old Mar 17, 2019 | 06:32 PM
Yellowstatue's Avatar
As referenced in your other post, that OS air cleaner is a '69.
Old Mar 17, 2019 | 07:09 PM
bry593's Avatar
'69 Vista?
Old Mar 17, 2019 | 09:20 PM
It doesn't matter. All 4 bbl 400 Vista & 442 used the same breather, different label > #624835 & 6424958 for W30, 1968.
Old Mar 18, 2019 | 02:39 AM
jollyolds's Avatar
pm sent
Old Mar 19, 2019 | 02:50 PM
1slowbird's Avatar
I have a 6424834 or air cleaner in the garage. I dont know if it'll work for you. I have no use for it. Let me know and I'll get some more pics later this evening.
Old Mar 19, 2019 | 07:35 PM
OE is a small block.
Old Mar 20, 2019 | 07:38 AM
bry593's Avatar
Yellowstatue, is the small block base physically different with regard to the valve cover tube location? I’m not worried about the stove pipe since my manifold tins are gone. My primary focus is getting my covers valve covers hooked up properly.
Old Mar 20, 2019 | 09:02 AM
allyolds68's Avatar
The snout opening is smaller
Old Mar 20, 2019 | 10:55 AM
bry593's Avatar
Slowbird sent me pics and is similar to the 1968 big block base except the snorkel doesn't taper. Might even be a bit longer as well.
Old Mar 20, 2019 | 11:13 AM
allyolds68's Avatar
I'm not sure what you mean. An OG air cleaner snout tapers, just not as much
OG:
https://classicoldsmobile.com/forums/parts-sale/96733-1968-olds-442-air-cleaner-og.html#&gid=1&pid=2
OE:
https://classicoldsmobile.com/forums...r-cleaner.html
Old Mar 20, 2019 | 12:55 PM
bry593's Avatar
Slowbird's air cleaner was for a small block. It looks much the same as a big block base, except the snorkel is not tapered.
http://i7.photobucket.com/albums/y27...psjdfwkqsc.jpg
Old Mar 20, 2019 | 01:38 PM
allyolds68's Avatar
That doesn’t even look like a 68 air cleaner
The two links to “for sale” posts I posted above are the correct air cleaners bases for the 68’s. There are other variations but other than the OAI and the 2 bbl, the only difference is in the cover stickers
Old Mar 20, 2019 | 02:11 PM
1slowbird's Avatar
This is what it says on the side of the air cleaner base.
Old Mar 20, 2019 | 04:00 PM
rocwal's Avatar
^8 air cleaner
I have an air cleaner off a 68 Olds 98 with 455 , 4 Bbl carb if this is what you want let me know . I can send you pictures and price
rocwal
Dan B
Old Mar 20, 2019 | 04:29 PM
bry593's Avatar
rocwal
Dan B
Thanks Dan. I am interested. I sent you a pm with my phone number for text of pics.
Old Mar 20, 2019 | 07:21 PM
The small block snorkel has a welded piece at the opening of the snorkel and is smaller. The big block snorkel is wider at the opening and no extra metal.
arcticman
Jan 20, 2019 02:20 PM
66-3X2 442
Sep 27, 2012 01:23 PM
arodenhiser
Jun 23, 2010 12:16 PM
grt05
Nov 3, 2009 02:30 PM
dan1s
Mar 13, 2008 10:38 AM
