Olds 394 thermostat housng
Old May 8, 2019 | 07:07 AM
70chevrolet's Avatar
Need!!! Please!!!! Cant believe nobody repops this.
Old May 8, 2019 | 08:17 AM
jensenracing77's Avatar
Someone made one on a 3D printer not long ago on here. It would take me a while to find the thread but maybe he could make another one?
Old May 8, 2019 | 08:18 AM
Here you go
https://classicoldsmobile.com/forums...rosion-125181/
Old May 8, 2019 | 09:14 AM
MichiDan's Avatar
It was a favor ... I'm afraid i don't have the resources to make another one. I would check on having that one welded. Mine was not broken but actually way worse than yours as it was totally shot fulls of holes from corrosion. i was able to find a guy who welded it up. That is now my back up part.
Old May 8, 2019 | 09:43 AM
Jandk's Avatar
Just a good idea or as a emergency repair....
I made mine from a piece of 8mm flat stock I believe it is called as a flange, and a 90 degree weld pipe fittings. Turned out beautyfull. It is a little taller than OE, but it does not matter at all.
Old May 8, 2019 | 12:28 PM
Yep. Looks like making it is the way to go
Old May 8, 2019 | 01:46 PM
Epic fail. In my previos attempt to re clock a different thermostat, My flange was too thin and when i tightened it down, it tweaked. 8mm or 5/16 sounds about the right thickness.. Prototype number 2 in the works.
stay tuned
Old May 9, 2019 | 12:33 PM
Jandk's Avatar
stay tuned
Before I made mine from scrath, I bought an adjustable Chevrolet 350 thermostat housing and modified it to fit. I never finished the process of making it pretty, then I made one from scrath.
Biggest challenge was not to warp the flange part when welding.
Old May 10, 2019 | 04:58 AM
MichiDan's Avatar
It'll work. Honestly though, your original can be fixed. I just dropped mine off at the local guy who does all the aluminum trailer and pontoon boat repair. $40 and water tight.
Old May 10, 2019 | 09:27 PM
Kyle's77cutlass's Avatar
I am pretty sure I have 1 of them if you still need
Old May 15, 2019 | 05:04 AM
all set! in the interest of saving time I just ponied up 100 bones and bought one on ebay.. who'd have ever thought. $100 for a water outlet,
Old May 15, 2019 | 05:12 AM
Years ago the thermostat housing on my 64 98 cracked in the same spot. I had it welded.
Excellent that you sourced a replacement. Post a pic when you get it back together!
Old May 15, 2019 | 03:26 PM
mpolds's Avatar
Might be able to help you with a N.O.S. at far less than what you spent for one (ouch!!)...
Let me know if you want a spare....
Always best to simply call me -- Craig -- 516 - 485 - 1935.....
Old May 15, 2019 | 06:34 PM
59-59-59's Avatar
$100?? You got screwed and paid the highest price on planet Earth. I mean you could of bought one for $70 on EBay.... and that includes the actual intake manifold as well
Old May 15, 2019 | 08:40 PM
Maybe paid a bit much, but what do you do?
If you are have a hard time to find the part, gotta pay the reaper
Old May 16, 2019 | 05:26 AM
Make sure you keep the broken thermostat housing. You can always have it repaired as a back up or at least toss it in the spare parts bin when you sell the car.
Old May 16, 2019 | 11:08 AM
MichiDan's Avatar
My 2 cents, $100 is not out of line. I looked on ebay for months and there were NONE. I called the tech advisor for these cars and even talked to Judy Badgely. NONE to be found.
Remember they are specific to last years of 394, and specific to 4 barrel cars too.
Old Jul 31, 2019 | 07:56 AM
Charlie Jones's Avatar
Phantom Phixer
If you're still looking for a thermostat housing , this one just popped up on E-Bay ;
https://www.ebay.com/itm/1959-60-61-...0AAOSw5RldI5m~
It's aftermarket , and is made of cast iron .
MichiDan
Nov 4, 2021 09:23 AM
INTRUDER
Dec 19, 2019 01:36 PM
SMOKEYMTNKUSTOMS
Jun 3, 2008 08:54 PM
metro411
Dec 27, 2007 11:10 AM
