Metal dash & upper cowl for 70-72
Old November 11th, 2013, 04:51 PM
507OLDS's Avatar
I could use a few metal dash sections and the upper cowl area where the windshield sits. Only looking for perfect pieces. Pitted or blistered parts not wanted. The metal dash part is for 70-72 Cutlass/442.
507OLDS is offline
Old November 11th, 2013, 05:25 PM
1001coins's Avatar
brian i have a perfect front section i saved from a 72 colorado 4 door chris
let me know if you want pics
1001coins is offline
Old November 16th, 2013, 08:41 AM
507OLDS's Avatar
TTT. Anyone out in the desert or west have one from a car they are cutting up? It can be any body style,as long as it is 70-72 Cutlass/442/Vista.
507OLDS is offline
Old November 16th, 2013, 09:22 AM
NOVICE car nut
oldsguybry's Avatar
I hope you find what your looking for . Mine is real bad . The rust hole goes all the way across.
oldsguybry is offline
Old November 18th, 2013, 04:57 PM
hawks70's Avatar
I have one. 70 Cutlass. Solid Texas car hit front hard. Parts you want still good. I'll be cutting it up soon as I get motor and trans out of it. If you can hang on a bit I will make you a good deal if its what you want. Pm me with an email and I'll get some pics for you. I'm just east of Rochester, NY so if you wanted to come get the parts you want you could make a day trip out of it. I'm trying to figure out how I'm gonna get to the driver side motor mount to get bolt out or cut mount on that side to get it out cause of how frame bent.....crushed driverside header into starter between the framerail so can't get to both ends of bolt. May have to fire up the sawzall for this too......
hawks70 is offline
Old November 18th, 2013, 06:45 PM
507OLDS's Avatar
If you want to strip the car if what you need,I could take the rest,or come up & cut what I need. I need to go to Rochester anyway,so I could make a day out of it.
507OLDS is offline
hilbily
Body work
September 9th, 2014 08:54 PM
rcktdoc
January 6th, 2014 08:46 AM
meoff
Body work
17
April 18th, 2013 06:24 PM
dallasite21
February 24th, 2012 01:34 PM
Alex72cutty
February 7th, 2012 07:32 PM
Quick Reply: Metal dash & upper cowl for 70-72
