cowl/upper dash repair
tackled this winter.was not looking forward to it but all in all wasn't that bad!
all cancer removed!er from dash cowl are anyhow!LOL
bought a doner repair piece!
and going back together!
weld and grind weld and grindLOL
after coating with fiberglass resin and sanding twice,laid a thin layer of bondo to pretty up twice as bondo sands a lot easier than resin!
primer still wet
and finally rust free satin black!
was brown interior before but have been purchasing all black over the years and finally a black dash!with the rust gone!not perfect by any means but turned out great for a driver/weekend strip car!
primer still wet
I have the same to do on my 70 but the cowl panel is going to.
The part that is under the glass is seamed to the cowl. Is there any other seams, supports, crap thoughts I need to know about to pull this off.
also the sides... got any better pics?
I have to cut it out od a four door but it all here.
the upper dash area right at lower windshield is spot welded to lower cowl section. here is drilling out spotwelds on doner to seperate. on car that area was already rusted away but did not rust lower cowl
as far as paint used a rattlecan, rust oleium,plastic,satin black.
tried a few different paints on other pieces and that seemed like the one that would hold up best long term!was really tough to sand down etc.
thanks for looking and replying.
probably have other pics if anyone needs more info.
I did cut on inside of roof pillars so I did not get into that area!
never found a aftermarket piece.who makes that?never know as it will probably come in handy on next one! they all rust there! LOL
time consuming,definately!measure 10 times and cut twice!
lol! pretty well ate up the winter and still puting back together.dash pad is on bench all pretty and ready to go back in.painted a new column as old one had shifter and now have floor shift.ready to start putting back together!
getting there!
I thought the dash pad mounting nuts were a real bear to remove!
but going back together with fresh paint and trying not to scratch really $ucked! I did manage a double scratch just below the heater controll and radio on the lower dash!
doing everything by myself so was going to happen sooner or later!
at least I was the one that put first scratch!
made a little more progress but no pics yet!
at least I was the one that put first scratch!made a little more progress but no pics yet!
this is a common problem on these cars and I recently finished repairing this area on my project car .time consuming ? yes very much to do it right. I made my own patch panels ,plural,upper dash and under that is the upper cowl ,had to repair\weld both pieces ,unfortunately didn't take pics so I can't show you how it was done ,only the finished results which you would be hard pressed to see the repair ,as it should be, but........... I can tell you that you are not done as the problem that caused the area to rust in the first place needs to be addressed which is no paint or seam sealer under this area and since you just welded on it, it will need corrosion protection.water drains into the upper cowl and that seam underneath is exposed to moisture constantly and since its not accessible to be able to paint completely I use a sponge[after sanding] and blot paint on the underside of the upper cowl and then seam seal using my fingers or a small stiff brush or both and checking my work [to make sure it is sealed] with a mirror.then I know all that work performed will last . stick your hand under there and feel .feel any rust? the open seam? here in the rust belt it would just rust out again,sooner than you think, since it will already have rust under there and you heated it up welding on it. both sides of a repair need to be finished!! today's lesson do it right the first time!!
