'70 W-25 hood metal frame piece....
Old Feb 10, 2018 | 10:28 AM
BSiegPaint's Avatar
I have a '70 OAI hood that has been hacked on. The front left and right front edges have been trimmed to make it a 71-72 hood. Badly, might I add. The fiberglass I can fix. But I would prefer to use some patched in original metal rather than fab up and bend bits and pieces to repair what's missing. So what I'm looking for is a pretty much destroyed hood where I could salvage the front edge metal. Anyone have such a beast? Bent is ok - as long as it can be unbent...
Old Feb 10, 2018 | 10:38 AM
Funkwagon455's Avatar
If you don’t have any luck with responses on this, I believe that Troy Thornton would sell the frame alone from his reproductions..
Old Feb 10, 2018 | 10:42 AM
BSiegPaint's Avatar
I'll keep that in mind - thank you
Old Feb 11, 2018 | 09:56 AM
Gary M's Avatar
Not mine
Old Feb 11, 2018 | 12:05 PM
BSiegPaint's Avatar
Thanks, Gary - the poster is actually on this site as well - worth a PM for sure...
Old Feb 11, 2018 | 12:18 PM
4speed455's Avatar
Could you use a regular steel hood as the source for the donor metal? Might be easier then making your own even if the don't match exactly
Old Feb 11, 2018 | 12:35 PM
BSiegPaint's Avatar
I'm not sure how I would separate the inner frame from the outer shell - honestly I haven't seen what the underside of a steel hood looks like. I'm thinking they would be measurably different.
Old Feb 11, 2018 | 05:49 PM
KardsHO's Avatar
I have reframed a W-25 hood from a donor (standard hood) albeit for a 72 not a 70. I believe any 70-72 hood would work and you would have to modify the frame at the ends. To remove the steel frame from steel hood you will need to drill out welds. One thing to note is that you will be triming the sides as the steel hood has the frame fold over (90 degrees) at edgges and this edge is deleted on W-25 hoods as they are panel bonded to SMC (fibergalss) top. Also, you would need to cut out the metal
for OAI on steel frame.
Steel frame is to the far right (sun roof parts next to them).
Old Feb 12, 2018 | 03:09 AM
BSiegPaint's Avatar
KardsHO, thanks for that pic - great information. It looks like I may have a lead on a couple frames from some OAI hoods - that's probably the best way to go....
Tripleblack74
Aug 21, 2017 05:53 PM
hilbily
Body work
Sep 9, 2014 08:54 PM
art72
May 8, 2013 05:17 PM
ELECMAN
Jan 11, 2012 03:36 PM
Indy_68_S
Brakes/Hydraulic Systems
Jan 2, 2011 09:23 AM
