Upper Dash Paint Finish Question
Old Oct 29, 2024 | 06:53 PM
Cincinnati Rick's Avatar
Should the black paint on the top of the dash be flat black or have a slight sheen to it. I'm saying flat but others say sheen.
Old Oct 29, 2024 | 09:35 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Its a % reduced gloss semi to allow for cleaning without being reflective. <Its not flat> Edit yep it is flat....., but it's not a porous flat like a flat interior house paint is where you rub up against it and it leaves a mark. The surface is sealed to allow cleaning. TX Joe. Your paint dealer will be able to mix it. I used a heavily reduced gloss on mine because I liked the look.
The paint codes are available here and at your local paint supplier who should be able to cross ref the Ditzler #s
I'm guessing by that steering wheel you are referring to a 68 dash.
https://www.autocolorlibrary.com/pages/classic-library
Old Oct 29, 2024 | 09:53 PM
Rick, the upper part of the dash directly below the windshield is flat. The lower dash is semi-gloss.
Old Oct 30, 2024 | 04:39 AM
Its a % reduced gloss semi to allow for cleaning without being reflective. Its not flat.
Thanks for the info.
Yes, it is a 68 although the steering wheel / column are there temporarily. I have a tilt column and OEM sport wheel for the final assembly.
Thanks Joe. Do you agree that there should be a slight sheen on the upper dash as described above? This is pretty much what my paint guy is telling me too.
Old Oct 30, 2024 | 08:53 AM
If you are looking for 100% correct as born with paint have the vendor mix a small amount of the original recipe and do a spray-out.
I was not too fond of the original mix from a durability or cleanability standpoint. If you wiped it with a paper towel it would leave paper towel remnants behind that were hard to make go away. I did not apply it "too dry"
I sanded it down and resprayed I think with a 60 or 70% gloss mix....35 years ago. It still looks new and doesn't collect dirt. That's a hard area to access for cleaning.
Old Oct 30, 2024 | 09:27 AM
Thanks for the comments.
My paint guy pretty much said the same thing as far as scratching and cleaning. His exact words were " if I shoot it with flat, your beer cans will leave marks". He is suggesting using a semi-gloss finish that he swears by. If it's too shiny for me, he said he can dull it down.
Old Oct 30, 2024 | 10:50 AM
70Post's Avatar
Then consider a semi-flat or, as an alternative, a satin mix (w/satin having more gloss than semi-flat) on the metal at the top of the dash. Semi gloss would be a higher gloss than the satin. Is the dash metal color going to be black? (not that the color matters for your question here).
IMO, a semi gloss is "too much" for the upper dash metal....but we're now talking about personal preferences.
Old Oct 30, 2024 | 11:56 AM
Rallye469's Avatar
This is what I gave my painter and he was able to get to a good place (I think).
Too much sheen? Not sure... looks good to me.
Old Oct 30, 2024 | 04:39 PM
That looks really nice. Thanks for posting the info and the pics.
Old Nov 13, 2024 | 10:03 AM
This is what we ended up with. I think it looks good.
Old Nov 13, 2024 | 10:40 AM
Yes sir. Nice!
Old Nov 14, 2024 | 07:17 AM
Rallye469's Avatar
Looks great! Congrats.
Old Nov 14, 2024 | 08:16 AM
Yes sir. Nice!
Thanks fellas.
Bullwinkle
Dec 14, 2024 08:09 PM
Doug Carner
Sep 10, 2024 06:59 PM
Shradezz70S
Jun 8, 2020 08:06 AM
55chevycraig
Jan 1, 2013 01:40 PM
skryla
Jul 22, 2011 12:51 PM
