Which shade paint
Old Feb 8, 2017 | 01:33 PM
denf221's Avatar
Which shade paint
Have a 72 supreme. Has anyone painted the metal radiator cover as well as the piece of metal under the cover that runs width of car in the original black? If so what shade did you use,flat,semi gloss,gloss? I painted mine with a flat black didn't turn out well. I want something that will clean up well,flat black doesn't. Also what brand paint do you think is best? What kind of primer? How many coats primer and paint? Any help would be great
Old Feb 8, 2017 | 01:56 PM
Rocketowner's Avatar
Smile What shade paint
I guess we would need to know what method you are using, Spray cans,spray
Gun,what type spray gun. Regardless of the answers from above ,you probably don't want "Flat black".Also tell us what are your plans for the car,daily driver, weekend local car shows,or even 100 point Show Car. Larry
Old Feb 8, 2017 | 09:16 PM
I used a Krylon semi-gloss black rattle can on mine. No primer, just hand sanded and sprayed.
Old Feb 8, 2017 | 09:59 PM
Eastwood's Underhood Black would be a good choice.
Old Feb 22, 2017 | 07:20 PM
denf221's Avatar
Thanks all
Old Feb 24, 2017 | 05:53 AM
rick442's Avatar
If you want gloss, I high recommend Mercuiser Phantom black. Also called Quick Silver. And if you really want it protected, use their clear coat. This stuff is great for all applications, suspension, engine, engine brackets.
Texas442
Paint
49
Jan 15, 2026 02:30 PM
JPMDaddy
Jan 14, 2019 08:41 PM
rustycragars
Dec 25, 2016 06:06 PM
desert442
Apr 18, 2008 11:24 PM
thomaswatk
Mar 22, 2007 01:31 PM
