red inner fenders
red inner fenders
i managed to get my red inner fenders under the hood clean but wheel well side has ground in (whatever and turning grey in spots). have tried everything on market and some home made solutions with no success. only option i have left is some kind of paint. really hate to do that but there that bad and ugly. does anyone know what color red and what paint to use, totally lost here.
Just a thought, take a picture of the good side and go to the store and look for some color coded trim paint. I'm not sure how you're going to get it to stick to plastic though.
If they are faded then use some 800 wet sand paper on them in just those spots and see how it does first. You can also use a heat gun after you sand them and bring some of it out that way. Just DO NOT use the heat gun till you have sanded as much of the bad stuff out as you can. After it is sanded it will still look white but the heat gun will melt that fine little stuff right off. After that is when it could still be possible to use a thin amount of SEM.
