Paint will not dry
Old Apr 17, 2023 | 09:03 PM
edzolz's Avatar
Paint will not dry
Anybody know if there is a way to make paint kick off and dry. I treated a pan with OSPHO to kill the rust and painted over it with Rust Stop enamel. It has been four days and still sticky, no change from first application. I may have to wash it with lacquer thinner and re-do.
Old Apr 18, 2023 | 02:12 AM
skyhigh's Avatar
1972 Cutlass Town Sedan
Just a guess but im thinking the humidity is really high, or its too cold, if its a 2 componet paint you didnt mix the right amount of hardner or you put way to many mills on for a single componet paint, i would thinner wash it and see what happens, if its not dry now it wont kick off.
Old Apr 18, 2023 | 04:20 AM
ijasond's Avatar
Purveyor of Polyurethane
If heat doesn’t do it, I would do as you stated. Wash it all off and start over. Make sure you follow the ospho directions exactly. It’s not compatible with all types of paint. Mainly epoxy.
Old Apr 18, 2023 | 05:43 AM
chopolds's Avatar
Not familiar with the product, but the name, Rust Stop, might indicate it is an MCU type paint, like POR-15. Moisture Cured Urethane. So if it's very dry out, it cures slowly. Even when it's hot. Try putting some water on the ground underneath the part, to give it some moisture, to cure with.
Old Apr 18, 2023 | 05:53 AM
^^x2^^
RustOff will dry in ~30mins. Start over.
Old Apr 18, 2023 | 09:22 AM
edzolz's Avatar
It is not a two part paint, not epoxy based, just oil based enamel. I tried my heat gun (gets very hot) did not help. I guess it will have to be washed off with lots of ventilation for the lacquer thinner to blow away.
Old Apr 18, 2023 | 09:41 AM
REO442's Avatar
I just did some paint work on my pickup truck, using Rustoleum oil-based enamel, temp was 62 degrees, added some Japanese drier, 36 hours later it was dry and no tack. 2 more days in the sun and it toughened up as expected. Oil-based enamel fully cures in a week.
Old Apr 18, 2023 | 04:07 PM
Funkwagon455's Avatar
If possible you can heat/cold cycle it to help it kick. Get it warm for a while in direct sunlight, cool off in air conditioning a couple of times and see if it will harden. If not, strip and reapply.
Old Apr 19, 2023 | 05:48 AM
If the paint never cured and you even used a heat gun (600*F+), then you should thoroughly clean the part and use a different paint. Since it wasn't a simple mixing mistake where you didn't add enough hardener.
Old Apr 19, 2023 | 06:31 AM
ijasond's Avatar
If it's oil based and not dried, you can probably use something much less harsh like mineral spirits. Just make sure it's thoroughly cleaned before you start again.
mattking
Paint
Dec 9, 2021 03:05 PM
RandyS
Paint
Jul 14, 2020 06:14 PM
scott strange
Paint
Oct 20, 2010 07:57 PM
2blu442
Body work
Feb 6, 2009 04:36 PM
Doug69Cutlass
Apr 18, 2008 11:02 PM
