Modern PPG Paint Code for 66 Olds fACTORY Paint Needed
Old Oct 1, 2025 | 01:03 PM
Tri-Carb's Avatar
Has anyone reproduced Royal Mist (1966 Code E) by using a modern PPG formula? (It is tricky because of the metal flake used in that mixture.) If you have done this successfully with PPG, can you post the formula?
Old Oct 2, 2025 | 03:28 PM
GAG1602's Avatar
Royal Mist (1966 Code E, WA2966/13002) is still in PPG’s system. Any PPG distributor can pull up the modern Deltron/Envirobase formula and adjust the metallic flake spec. Best bet is to bring them the code or a panel for scan and they’ll print the current formula for you.
Old Oct 3, 2025 | 02:40 AM
Tri-Carb's Avatar
Many thanks.
ourkid2000
Paint
Jan 17, 2025 08:07 AM
70-455
Aurora
Jul 19, 2024 04:36 AM
zl1 camaro
Sep 22, 2023 04:38 AM
Tymiles24
Jan 17, 2018 02:42 PM
squirell
Nov 8, 2009 04:38 PM
