Modern PPG Paint Code for 66 Olds fACTORY Paint Needed
Has anyone reproduced Royal Mist (1966 Code E) by using a modern PPG formula? (It is tricky because of the metal flake used in that mixture.) If you have done this successfully with PPG, can you post the formula?
Royal Mist (1966 Code E, WA2966/13002) is still in PPG’s system. Any PPG distributor can pull up the modern Deltron/Envirobase formula and adjust the metallic flake spec. Best bet is to bring them the code or a panel for scan and they’ll print the current formula for you.
