1970 Green special order paint
Old Jun 7, 2016 | 09:22 AM
  #41
My first guess would have been Chevy Rally Green, but with the data tag evidence of 46 once there, I would go with Ming Jade. TCP Global does have a match for it.
Old Jun 8, 2016 | 06:24 AM
  #42
rand5204's Avatar
Orange442.
You're correct. Code 19 is black not platinum. It still seems odd to m e that the wheels would not be body color and that it's called out on the build sheet
Old Jul 19, 2016 | 09:38 AM
  #43
joeyg's Avatar
I can tell you for sure this color is MING JADE code 46. I special ordered my 70 in this color, wonder if this was my car...
I'm reliving my old car, in the process of painting my 70 442 convert this color.
Originally Posted by oldsmobilty
Under the door panel
Inner rear wheel well
Color book labeled 1970 GM colors
Old Jul 19, 2016 | 11:55 AM
  #44
oldsmobilty's Avatar
Joeyg I bought this car in Louisville, Ky. I believe from the original owners daughter. It also has the protecto plate. Maybe just a coincidence you both ordered the same car
Old Jul 19, 2016 | 12:32 PM
  #45
joeyg's Avatar
WOW what a coincidence, I know of at least one 442 that was ordered from the factory Ming Jade and one Cutlass Supreme and now yours, now were up to three!
Were you able to find the correct paint?
Joe
Old Dec 22, 2016 | 05:27 AM
  #46
allyolds68's Avatar
I figured I'd dump this link in here because I thought it was unique.
Every special order paint code I've seen in 68 was either "- -" or, if it was an Oldsmobile color, it was the Oldsmobile code... ie: the 68 H/O with the "Z Z" paint code. This 68 Oshawa Cutlass S has a "Q Q" paint code with is a Pontiac code (Verdoro Green Metallic).
http://www.oldsmobilecentral.com/for...l-tag-info.php
Old Nov 19, 2017 | 04:59 PM
  #47
NUGGET69442C's Avatar
1969 Olds 442C - Nugget Gold
Restored to Perfection - - - Numbers Matching.
Old Nov 19, 2017 | 08:07 PM
  #48
11971four4two's Avatar
MOTORHEAD
Off the track --b
granted 1968 not 1970
I do have a tag - - specialorder paint
It shows --B 2 special order colors with "B" black roof tag came from a 442 / cutlass
Old Nov 19, 2017 | 08:46 PM
  #49
lunaboy's Avatar
The Rocket Astronomer
don't forget about this green on an Olds... "First things first, the paint code on this unbelievable car is merely two dashes indicating it was a special order color-in this case, Rally Green"
Old Nov 19, 2017 | 09:19 PM
  #50
Jon442's Avatar
Gearhead
A friend of mine ordered a new 1968 442. At the time, he worked for a funeral home that had it's vehicles painted a shade of baby blue. He wanted his 442 painted that color, and they did. Not sure how he got the paint code to them or what the process was, but it was the same color as the hearses.
Old Nov 19, 2017 | 09:35 PM
  #51
MOTORHEAD
refresh
thanks
gristle
Diego
Aug 4, 2014 05:23 PM
LI Olds
Dec 24, 2012 04:06 PM
GAOldsman
Dec 20, 2012 07:14 AM
jensenracing77
Paint
Jul 22, 2012 09:46 AM
klilly80
Jul 6, 2008 12:11 AM
