Paints: black sheen
Old Nov 20, 2017 | 09:18 AM
NotDads442's Avatar
Paints: black sheen
1967 442
For the following areas that have black paint, what sheens (gloss, semi, satin, flat) are correct?
Headlight trim recesses
Firewall
Inner fender/wheel wells
tail light recess in quarter panel/"OLDSMOBILE" script bar on trunk
Radiator core support
Old Nov 21, 2017 | 09:18 AM
mrolds69's Avatar
I think this is kind of a trick question, that's why nobody's answered. I don't know 67 Olds for sure, but I know 60's 70's GM in general. Nothing I can think of under the hood was flat. Not much was gloss. Things like the core support were typically semi, satin, eggshell, lots of different names for the shades of black. The parts were painted at separate times and sprayed or dipped at different temperatures, heats, paint batches, etc. Also underhood heat has changed some of the colors. Radiators are typically glossier than the core support, horns are typically glossier than radiators. You can get some variation from the same color by spraying distance or thickness of coats. Most things were like 80% or so, gloss. See what others say.
Old Nov 21, 2017 | 02:51 PM
My442's Avatar
Eastwood sells under hood paints that look really good.
The variability in GM plants at that time was huge.
O's_Car
Oct 1, 2021 04:52 AM
nsnarsk65cutlass
Jan 3, 2016 09:21 AM
zodiacblue442
Paint
Sep 29, 2015 04:57 PM
blunce
Sep 18, 2014 08:49 AM
montvaleplace
Paint
Jun 29, 2009 05:58 PM
