missing vacuum hose
Old April 25th, 2018, 07:35 PM
ej69's Avatar
missing vacuum hose
1969 cutlass s convert, v8/4bbl w/ a/c, pb
going over the engine, i notice, what i assume is a vaccum can, on the driver side tucked under fender by firewall. There is a vacuum line going off can an into firewall to under the dash. The other port on the can has nothing going to it. I assume a vacuum line from the engine goes to it. what is this for. I have looked in my manual and it appears something to do with heating/cooling?
thanks.
ej69 is offline
Old April 25th, 2018, 07:37 PM
Old School Olds
tru-blue 442's Avatar
Do you have a trunk release button in the glove box?
tru-blue 442 is offline
Old April 25th, 2018, 07:47 PM
ej69's Avatar
i do, it doesnt work and ive never really looked into it. i figured it was electric operated.
thanks
ej69 is offline
Old April 26th, 2018, 07:28 AM
The A/C flapper doors under the dash are vacuum actuated. There is a vacuum can on the firewall to act as a reservoir for this system. Normally, there is sufficient manifold vacuum to operate these actuators, but if you step on the gas, manifold vacuum drops briefly. The reservoir serves to maintain the function of the vacuum actuators during this period of low manifold vacuum. If the can is not connected, you may just not have noticed the temporary drop-out of vacuum under acceleration.
If you have a vacuum trunk release, there would have been a separate vacuum canister for that system. That canister is intended to retain vacuum to allow you to operate the trunk release after the engine is turned off.
joe_padavano is offline
Old April 26th, 2018, 08:03 AM
mrolds69's Avatar
It is for the trunk release, that's where my can is. It needs to be tee'ed into the main vacuum to work.
mrolds69 is offline
jdana24
June 22nd, 2017 09:26 PM
Robert Zuijdam
May 11th, 2016 06:42 AM
Sampson
March 24th, 2015 09:33 AM
jrbarrie83
July 9th, 2006 09:26 AM
daddyjws
December 21st, 2003 04:04 AM
Quick Reply: missing vacuum hose
