stalling issue
Old April 12th, 2018, 05:23 PM
crazy'boutOlds's Avatar
stalling issue
I have a 1976 Cutlass with a 260. After driving, I'll go to back it in to a parking spot and it stalls everytime. I took the a/c belt off because the compressor is bad. That wasn't it. Had my carb rebuilt, but that did nothing as well. I'm at a loss.
​​​​​​​The newer cars have a cut off switch, does a 76 have one? I would guess not, but not sure.
crazy'boutOlds is offline
Old April 12th, 2018, 05:52 PM
Sugar Bear's Avatar
Does it stall in reverse only? Try putting it into neutral and then back into drive instead of reverse to see if it stalls.
Is the stalling very sudden/abrupt or does it give some warning and stall over a few seconds?
This would not be reverse only but the EGR valve could be sticking open causing a vacuum leak.
Cut-off switch...no, not equipped.
Good luck!!!
Sugar Bear is online now
Old April 12th, 2018, 05:56 PM
No warning, can I plug the vacuum hose going to the egr? Would that help?
Old April 12th, 2018, 06:50 PM
Sounds like it probably needs a tuneup.
oldcutlass is online now
Squatch7795
August 29th, 2016 06:41 AM
Firstcutlass
October 5th, 2011 06:21 AM
rlafash
August 22nd, 2011 12:40 PM
Giddy
August 6th, 2008 01:56 PM
chancestoo
December 8th, 2006 05:22 AM
Quick Reply: stalling issue
