Weird stalling issue when car warms up
Old Aug 26, 2016 | 09:10 AM
Squatch7795's Avatar
Alright.i have a 1983 delta 88 royale. Lately im having a weird issue. My car will start and idle alright but when i put it in drive or reverse and hit the gas, it doesnt move at all and just syalls out. It seems to only do it when the car gets warm. I know this cuz when i got up this morning it was able to be driven into my garage but after having it run for a lil while it just syalls in gear. Idk what it could be. I have checked all vacuum lines and all are intact. Any ideas?
Old Aug 26, 2016 | 09:17 AM
Are you sure you checked ALL of the vacuum lines? An '83 Delta probably has about a thousand of them.
Any chance you have a spark plug wire off, or a carbon trial in your distributor cap, or a bad spark plug wire, or a bad spark plug?
I'd eliminate all of those things first, before considering readjusting the idle, since it shouldn't have changed if you didn't mess with it.
Old Aug 26, 2016 | 09:22 AM
76olds's Avatar
Hookers under Hood
I agree with Eric, if its chugging when you give it gas then stalling, its likely spark related.
Old Aug 26, 2016 | 09:26 AM
rocketraider's Avatar
Oldsdruid
I've seen bad lockup converter switches cause this if converter stays in lockup mode. Is "check engine" lit?
Old Aug 26, 2016 | 09:31 AM
Forgive me for being uneduacted in some of this stuff, im still learning. What is a carbon trail?
Old Aug 26, 2016 | 09:49 AM
Check engine light is not lit. I even did the aldl jumper thing and no codes came up except for 12 which i was told it did b4 starting the actual codes
Old Aug 26, 2016 | 09:56 AM
Well i guess i just found the problem... it looks the the center of the isnide of the cap, along with the rotor has melted somehow, which opens up another mystery as to how in the heck this happened
Old Aug 26, 2016 | 10:03 AM
That'll do it.
A lot less subtle than a carbon trail.
Is that just the cap that's damaged, or is the coil damaged, too?
76olds's Avatar
Hookers under Hood
Where is the insulator washer and brush pin? Did someone do a tune up on it recently and install it incorrectly?
Eric
Old Aug 26, 2016 | 11:56 AM
Damn, skippy.
Old Aug 26, 2016 | 12:01 PM
Oldsdruid
Hully jayzus that's ugly. Never seen anything like that.
Old Aug 26, 2016 | 01:08 PM
76olds's Avatar
Hookers under Hood
Oh X2, that's worth saving just for a conversation piece.
Eric
Old Aug 26, 2016 | 05:31 PM
Railguy's Avatar
It's amazing how bad those can get and still run.
Railguy
Old Aug 26, 2016 | 07:48 PM
Chris J's Avatar
Had to chime in on this one....I've never seen anything like that either! I seen a few that were pretty messed up...but that takes the cake. I agree you should defiantly keep that one cuz nobody's gunna believe that one.
CJ
Old Aug 29, 2016 | 06:41 AM
Update: i finally replaced the cap, rotor, button, and the coil. It idles fine but when i put the car in gear and hit the gas it moves maybe an inch and still just stalls out.
jpc647
Nov 11, 2014 02:26 PM
costpenn
May 26, 2014 10:11 AM
78ChevOlds
Jun 30, 2013 09:52 AM
leroycjr
Aug 31, 2011 09:32 AM
GoodOldsGuyDougie
Brakes/Hydraulic Systems
Nov 22, 2010 08:07 AM
