Other Oldsmobiles Anything not listed above, such as F-85 (1961-1963), Firenza (1982-1988), Starfire (1961-66 and 1975-80), Omega, etc.
61 Dynamic shift linkage setup??
Old August 13th, 2011, 09:06 PM
buz
buz's Avatar
I have a 61 Dynamic that is pretty much original. I When I bought it the carb linkage was (and still is) kinda jury rigged. The kick-down linkage is completely missing. It is a stock 394 4 barrel with a hydramatic. Lota fun to drive but I always shift manually and would like to fix that problem. Thanks for your help in this problem.
buz is offline
Old August 14th, 2011, 07:30 AM
Oldsdruid
rocketraider's Avatar
You need a 1961 Oldsmobile Chassis Service Manual and some special tools to adjust that linkage. The manual will show the linkage and adjustment procedures.
Go over on aaca.org Olds forums and search Hydramatic, then look for dlh61olds who is Dave Holt in Colorado. He had some of those adjustment tools made and may still have a few. He's been over here before too under the same ID, so may be able contact him thru here. He has 61 Oldsmobiles and understands them well.
You can do it by trial and error, but it's time-consuming. The adjustment needs to be correct for the trans to work properly, and misadjustment can cause transmission failure.
rocketraider is online now
Old September 9th, 2011, 09:41 AM
Tedd Thompson's Avatar
buz, As Rocketrader said go to the AACA. forum.Look under Oldsmobile technical. There is a sticky that goes into much detail on this subject.Good luck with your Slim-Jim, if they are good they are good, if bad you would rather have a Rambler....Tedd
Tedd Thompson is online now
oldzy
December 10th, 2010 02:38 PM
tarheeldoc
June 5th, 2009 11:38 AM
Bunser
March 27th, 2008 05:23 PM
Kennybill
May 10th, 2007 12:52 PM
Quick Reply: 61 Dynamic shift linkage setup??
