Weatherstripping help
Old Jan 9, 2013 | 08:46 PM
71cutlass350's Avatar
Hi I have a 1971 cutlass s and I was wondering if they make replacement weatherstripping for around the front and rear windshields or if you can just use any old weatherstripping? Thanks
Old Jan 10, 2013 | 05:30 AM
rocketraider's Avatar
Oldsdruid
These cars use tape weatherstrip to seal the stationary glass to the body. Any good body shop supply will have it. There are a couple versions of it and glass will have to be removed and the body channel cleaned to get a good seal.
A glass shop can do it for you cheap enough.
If you're just getting some water leakage they use a rubberized caulk sealer to fill gaps between teh glass and the seal tape, but they'll need to be sure what type of tape is in there as some of it is incompatible.
Old Jan 10, 2013 | 10:11 AM
ROCKET VAPOR's Avatar
Lance
Some reading material on this subject
http://www.chevelles.com/forums/showthread.php?t=378342
Old Jan 11, 2013 | 11:22 AM
Just to clarify, there is no weatherstripping around the windshield and back window on these cars. The glass is glued into place using a butyl rubber tape adhesive. FYI, if you are getting water leaks here, expect to find the dreaded pinchweld rust, which is all too common on these cars.
Old Jan 11, 2013 | 12:36 PM
jfb's Avatar
jfb
if you are talking about the inside window area and yours are not ripped dye them properly or get decent used ones and use a industrial heat gun to meld back to shape.
442_Mustang
Jul 7, 2018 06:48 AM
jread199
Oct 16, 2012 07:45 AM
DAN76
Oct 14, 2008 06:22 AM
Omicron
Jul 5, 2008 09:03 PM
Doug69Cutlass
Apr 15, 2008 04:50 PM
