Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
What's wrong with this picture?
Old Apr 19, 2013 | 05:16 PM
Seen today at a flea market:
Old Apr 19, 2013 | 05:24 PM
Clever. Two barrel onto a four barrel manifold without an adapter.
Old Apr 19, 2013 | 05:28 PM
Octania's Avatar
Damn pretty NOS DualJet faux QJet!
Nothing wrong with that at all.
How much?
Old Apr 19, 2013 | 05:29 PM
Usually, DualJet refers to a Rochester carburetor that is functionally the same as the primary portion of a QuadraJet, but with only the front half of the body, and with a unique smaller bolt pattern and air cleaner opening.
I had not been aware of the existence of this version, which is for a late-'60s [whoops!] Pontiac (which is why I put it in the non-Olds-powered section ).
Originally Posted by Octania
How much?
Sorry, I don't recall - lots and lots of walking and looking at stuff, and I had no interest in it myself, so I didn't file that information away.
Old Apr 19, 2013 | 05:35 PM
Octania's Avatar
Late 60's Pontiac?
Hmmmmm.....
My memory says early smog era Olds. Like 1976-77 260 engine. Ck the pix of every intake in the other thread, see if the A2 intake takes a QJet bolt pattern like this.
Carb number would the application tell of course.
Worth some coin just for the NOS parts- screws, jets, power piston, primary throttle shaft maybe, choke coil, vacuum break unit...
Old Apr 19, 2013 | 05:38 PM
Late 60's Pontiac?
Whoops!
Total typo. Thought I'd hit the adjacent key and written "'70s."
The DualJet, in any configuration, was definitely a late-'70s / early-'80s carb.
My mistake.
Old Apr 19, 2013 | 05:40 PM
classicmuscle442's Avatar
Thought the dual jet was the '64'65 four barrel carb, before quadrajet?
Old Apr 19, 2013 | 05:44 PM
No way, José.
The pre-QJ 4bbl of which you speak was the 4GC, also known as the 4-Jet.
It was structurally the big brother of the 2GC, or 2-Jet, commonly used on all 2bbl motors from the late fifties through the early seventies.
It was (briefly) replaced by the DualJet because the DualJet's (ie: the QuadraJet's) metering system allowed for tighter mixture control for emissions.
Old Apr 19, 2013 | 06:15 PM
brownbomber77's Avatar
Yeeeeup
Late 60's Pontiac?
Hmmmmm.....
Fo sho...took one of those nastys off my 260 and plopped it on a 455. Literally could not rev the stock cammed with headers 455 past 3500RPM. They flow 243CFM or something...
Old Apr 19, 2013 | 06:18 PM
Tony72Cutlass'S''s Avatar
WHY wouldn't you want 4 barrels to a carburetor?
It seems my carb operates on two barrels unless you really jam your foot to the floor. Then it's just pure awesome all the way to 80MPH.
Old Apr 19, 2013 | 06:24 PM
Hmmmmm... it does get one thinking...
"Sure, Son, you can borrow the 442 for the prom, just let me tune it up for a few minutes first [Heh, heh, heh]"
Old Apr 19, 2013 | 06:26 PM
Because a 260 simply can't use that much air under any circumstances, short of revving it to 12,000 RPM.
There's no point in GM spending the money on the extra bits of the carb which will never be used.
Old Apr 19, 2013 | 07:37 PM
Ya, I thought they put these on the 231's as well. I even had trouble running my 260 with headers up to 5500, damed thing quit making power at 4000RPM. Yes, this is an excellent idea for those of you with children...
Old Apr 19, 2013 | 09:32 PM
BILL DEMMER's Avatar
Just the facts...
also used on poncho 301's from '77-'79 or so.
saved costs on engineering a new carb.
later, they just cut-off the back half and called it a dual jet 210
they are funny to look at, never had the chance to crack one open for a chuckle.
bill
Old Apr 20, 2013 | 03:31 AM
Yellowstatue's Avatar
I have one of those lurking in my basement
Old May 23, 2013 | 07:57 PM
junkyardjeff's Avatar
I seen one on a 69 impala with a 396.
Old May 23, 2013 | 08:11 PM
65B01Delta's Avatar
I had one that I use to put on my 69 442 during the winter months back in the day and it ran good with it on there. The carb came off of a 78-77 Omega with a 260 V-8.
Old May 23, 2013 | 08:20 PM
copper128's Avatar
Lt. Buzzkill (ret.)
Hmmmmm.....
Chris, I know my 75 Cutlass Supreme 260 definitely had that carb.
joe_padavano
Mar 5, 2013 05:26 PM
Blackpage
Jan 23, 2013 06:32 PM
kjr442
Jul 25, 2011 02:11 PM
MDchanic
Nov 3, 2010 12:48 PM
don71
Mar 23, 2008 02:27 PM
