B/C Body Headers
B/C Body Headers
Does anyone know of high quality headers that will fit 71-76 B and C bodies without modifications? I already know that Doug's Headers makes a set. However, they are a bit pricey. Does anyone know if the following headers would fit, or are they just junk that would have to be beaten into submission?
http://store.summitracing.com/egnsea...115+4294907990
If nobody knows, then perhaps someone has the contact information for the OCA B/C body advisor. Perhaps they know...
Every listing I've ever seen indicates that the A-body headers also fit the 71-76 full size cars. The 71-76 cars use the same motor mounts as the A-body, and unlike the 65-70 cars they are front steer, so I suspect you'll be OK.
Thanks Joe. That is what I was suspecting, I just didn't know if anyone had any experience with any of the listed headers. Summit says any of those headers would fit the 71-76 B/C body. I guess the question would be if any of them required "modification."
When I was putting my Delta back together 4 years ago I had some headers laying around, not sure what brand or application they were or what they were "suppose" to go on, maybe an A-body. I put them in when installing the engine back in my 1971 Delta. A little "modification" on driver's side near proportioning valve, and the down tubes seemed a little short being that the collectors touched the top of the floor. I heated the tubes before the collectors and pulling down on the collectors, re-benting it down-ward a tad for a better angle away from the floor and a straighter shot at the cross-member. I put a torque tube on along with dual exhaust. It wasn't to bad and the price was right, free. Look around for a used set cheap. Headers and dual exhaust will probably give you around 20-25 HP and a little more torque. My Delta's probably a true 350 hp at the flywheel. Good luck, Ken
I'm glad you brought this up olds64, because I was trying to figure out the same thing. headers and true duals is a mod I've been dying to do to my 98 for a while, and I'm hoping to accomplish that by this summer.
-Bob
-Bob
-Like my 98..
