455 heads
455 heads
okay I got a 455 today .just wanting to know if the heads are worth saving ( Ka ) baged, it came from a boat and they built it up from the paper work found in the boat I am going to see if the guy will let me have the paper work it didnt think to ask if I could have it when i grabbed the motor. pulled intake off heads and block look newer / rebuilt no carbon build up but block has a few cracks from water freezing (396021Fa ) my hopes are to find a block and use these internals
cam crower 284 hdp
just wondering the foarms opions thanks justin
cam crower 284 hdp
Cool! I've picked up at least three boat motors with cracked blocks. Its easy to forget to drain the blocks in the fall, winter freezes and that's all she wrote!
They used manual transmission flywheels on boat motors... so if your able snag that too! Since all the use it has is the starter turning the ring gear the face of the flywheel is like new.
I'm suspect you can find one closer, but I do have extra blocks if you strike out.
John
John
He kept fly wheel stater and the lifters it's kinda sad the block was redone three years ago bored 30 over if the paper work is correct I am planning on getting head checked out but not sure if I will use the cam from what I read it will just kill my rear end and two speed trans lol
Yeah picking is slim Hear people seem to think they are gold I found a 74 with j head completely tore down with that sat out side for a year and he wanted 300.00 offered 100.00 and he still had it hoping I can talk some since into him but if not I might be interest to see what one would cost From you John
That's my plans two cylinders have some rust but you can still see the cross eching on the walls and two. Water ports are full of sand not sure if he ran into a bank or what
Are the distribitor different in boats ? It looks odd to me
It may be something aftermarket. But the distributor should be the same and interchange just fine. I remember getting one once that had been run in salt water on a jet boat. The exhaust ports were incredibly corroded! But your location should be lakes and maybe rivers so I'd expect it to be a treasure trove of parts.
John
John
Yeah he gave me accell high out put coil too this just looks off to me
Lol wife was so mad that I brought this home told her its worth something look what I got m t valve covers nice shape Mallory dis looks odd but will figure that out accel high out put coil and ka heads and crower cam maybe there is gold in them after all lol
Pic of block
761691C2-1B35-4D83-AB64-D4F5A340E4D8-28800-00001722B04E4843.jpg1CAF6342-787E-4E5B-BB29-7A555A450AFA-28800-00001722BB5FB866.jpg
The right bank is where the block cracked
Got any pics of the crank? You already know the block is toast, but the low compression pistons aren't worth using even if they are good. Make sure to keep the oil fill tube baffle, oil galley plugs, etc. Those are all things you can never have too many of
No pics of crank yet have not got oil pan off yet to pull bottOm end apart hear are cam heads and intake tho
FEF54632-066F-437E-80C6-F22345FB521E-28878-0000172C4CBEC799.jpgCF196483-9391-4A5F-8739-E0E2FA1D1A94-28878-0000172C5824665F.jpg61290A68-D0FB-41DE-AC15-887F91EB1DBB-28878-0000172C62B261AA.jpg9AA0FF8C-92B4-4351-B850-A220B441F491-28878-0000172C6C4552B7.jpg
Well, they aren't factory pistons so they can't be identified by the "V" or rounded notches. Unless I just can't see them in the picture...but looking at the dish they look like low compression pistons. The high compression pistons have a really small dish in them.
dishes
My machinist called my old low comp pistons "cereal bowls". They looked a lot like yours. My replacements have an 18CC. dish, but with a little additional milling, and decking, I calc. at 9.65:1. Plenty good for my weekend cruiser.
Here are some of the factory style replacement pistons available for 455. The pictures will give you an idea of what the differences are for high and low compression pistons.
High compression:
http://www.kb-silvolite.com/silv-o-l...tails&S_id=294
Low compression:
http://www.kb-silvolite.com/silv-o-l...tails&S_id=293
High compression:
Low compression:
Washed the heads today getting ready to go out to get checked look pretty good couple valves had rust don't look real bad
Got the oil pan off and snapped a few pics
Looks pretty clean
So if any one can answer this is there adifference in the rods from auto to marine engine I read that there is what are the pro and cons of using marine rods ??
Thanks for all the help and great info from every one
Looks pretty clean
I thought they did it to balance but I don't know much about internals build up very well
I think I might have enough sand to build a castle with my kids it just kept pooring out of the water jackets even a chunk if glass don't know where they went boating but man the must of loved the beach
Yeah the one that looks beat up looks like lead as well sorry my I phone don't take the best pics it looks like they tryed to smooth it with a stick ?
Over all all the bearings looked good I could still read the ink on them Hopefully the crank and rods are useable Not really sure what pistons to use all the ones I been looking at are expensive 😱
That looks like a Mallory Unilite distributor. I can do a few different 455 engines as well. lemoldsnut@aol.com I am in Redmond, Oregon
ut442
Mar 9, 2012 11:57 AM
thats deep
