455 heads
Old Sep 29, 2012 | 07:54 PM
oldstata's Avatar
Justin
455 heads
okay I got a 455 today .just wanting to know if the heads are worth saving ( Ka ) baged, it came from a boat and they built it up from the paper work found in the boat I am going to see if the guy will let me have the paper work it didnt think to ask if I could have it when i grabbed the motor. pulled intake off heads and block look newer / rebuilt no carbon build up but block has a few cracks from water freezing (396021Fa ) my hopes are to find a block and use these internals
cam crower 284 hdp
just wondering the foarms opions thanks justin
Old Sep 29, 2012 | 08:16 PM
copper128's Avatar
Lt. Buzzkill (ret.)
Ka's are excellent heads. Big valves too.
Old Sep 29, 2012 | 08:35 PM
2blu442's Avatar
Cool! I've picked up at least three boat motors with cracked blocks. Its easy to forget to drain the blocks in the fall, winter freezes and that's all she wrote!
They used manual transmission flywheels on boat motors... so if your able snag that too! Since all the use it has is the starter turning the ring gear the face of the flywheel is like new.
I'm suspect you can find one closer, but I do have extra blocks if you strike out.
John
Old Sep 29, 2012 | 08:39 PM
oldstata's Avatar
Justin
He kept fly wheel stater and the lifters it's kinda sad the block was redone three years ago bored 30 over if the paper work is correct I am planning on getting head checked out but not sure if I will use the cam from what I read it will just kill my rear end and two speed trans lol
Old Sep 29, 2012 | 08:45 PM
oldstata's Avatar
Justin
Yeah picking is slim Hear people seem to think they are gold I found a 74 with j head completely tore down with that sat out side for a year and he wanted 300.00 offered 100.00 and he still had it hoping I can talk some since into him but if not I might be interest to see what one would cost From you John
Old Sep 29, 2012 | 08:56 PM
2blu442's Avatar
If you haven't completely torn it down yet, you might check out the pistons. Depending on how many trips he made to the lake you might have a nice rotating assembly there
John
Old Sep 29, 2012 | 09:01 PM
oldstata's Avatar
Justin
That's my plans two cylinders have some rust but you can still see the cross eching on the walls and two. Water ports are full of sand not sure if he ran into a bank or what
Are the distribitor different in boats ? It looks odd to me
Old Sep 29, 2012 | 09:08 PM
2blu442's Avatar
It may be something aftermarket. But the distributor should be the same and interchange just fine. I remember getting one once that had been run in salt water on a jet boat. The exhaust ports were incredibly corroded! But your location should be lakes and maybe rivers so I'd expect it to be a treasure trove of parts.
John
Old Sep 29, 2012 | 09:11 PM
oldstata's Avatar
Justin
Yeah he gave me accell high out put coil too this just looks off to me
Old Sep 29, 2012 | 09:18 PM
2blu442's Avatar
Well... I'd say its an aftermarket HEI setup looking at the plug. Any tag on it anywhere?
Old Sep 29, 2012 | 09:23 PM
oldstata's Avatar
Justin
Pulled cap off the module reads Mallory And the contacts look new lol
Old Sep 29, 2012 | 09:27 PM
2blu442's Avatar
Treasure Found!
John
Old Sep 29, 2012 | 09:30 PM
oldstata's Avatar
Justin
Lol wife was so mad that I brought this home told her its worth something look what I got m t valve covers nice shape Mallory dis looks odd but will figure that out accel high out put coil and ka heads and crower cam maybe there is gold in them after all lol
Old Sep 30, 2012 | 12:59 PM
oldstata's Avatar
Justin
Pic of block
761691C2-1B35-4D83-AB64-D4F5A340E4D8-28800-00001722B04E4843.jpg1CAF6342-787E-4E5B-BB29-7A555A450AFA-28800-00001722BB5FB866.jpg
The right bank is where the block cracked
Old Sep 30, 2012 | 01:16 PM
ah64pilot's Avatar
Got any pics of the crank? You already know the block is toast, but the low compression pistons aren't worth using even if they are good. Make sure to keep the oil fill tube baffle, oil galley plugs, etc. Those are all things you can never have too many of
Old Sep 30, 2012 | 01:29 PM
oldstata's Avatar
Justin
No pics of crank yet have not got oil pan off yet to pull bottOm end apart hear are cam heads and intake tho
FEF54632-066F-437E-80C6-F22345FB521E-28878-0000172C4CBEC799.jpgCF196483-9391-4A5F-8739-E0E2FA1D1A94-28878-0000172C5824665F.jpg61290A68-D0FB-41DE-AC15-887F91EB1DBB-28878-0000172C62B261AA.jpg9AA0FF8C-92B4-4351-B850-A220B441F491-28878-0000172C6C4552B7.jpg
Old Sep 30, 2012 | 01:33 PM
oldstata's Avatar
Justin
So they are low compression positions darn was hoping they were useable I take it the high compression ones have no dish ?
Old Sep 30, 2012 | 01:57 PM
ah64pilot's Avatar
Well, they aren't factory pistons so they can't be identified by the "V" or rounded notches. Unless I just can't see them in the picture...but looking at the dish they look like low compression pistons. The high compression pistons have a really small dish in them.
Old Sep 30, 2012 | 02:15 PM
oldstata's Avatar
Justin
I believe on the edge they have two notices next to each other if the helps
Old Sep 30, 2012 | 02:22 PM
zodiacblueS's Avatar
dishes
My machinist called my old low comp pistons "cereal bowls". They looked a lot like yours. My replacements have an 18CC. dish, but with a little additional milling, and decking, I calc. at 9.65:1. Plenty good for my weekend cruiser.
Old Sep 30, 2012 | 03:13 PM
ah64pilot's Avatar
Here are some of the factory style replacement pistons available for 455. The pictures will give you an idea of what the differences are for high and low compression pistons.
High compression:
http://www.kb-silvolite.com/silv-o-l...tails&S_id=294
Low compression:
http://www.kb-silvolite.com/silv-o-l...tails&S_id=293
Old Sep 30, 2012 | 03:24 PM
oldstata's Avatar
Justin
Thanks I would have to say low compression
Old Oct 2, 2012 | 01:33 PM
oldstata's Avatar
Justin
Washed the heads today getting ready to go out to get checked look pretty good couple valves had rust don't look real bad
Old Oct 13, 2012 | 04:55 PM
oldstata's Avatar
Justin
Got the oil pan off and snapped a few pics
Looks pretty clean
So if any one can answer this is there adifference in the rods from auto to marine engine I read that there is what are the pro and cons of using marine rods ??
Thanks for all the help and great info from every one
Old Oct 13, 2012 | 05:03 PM
ah64pilot's Avatar
What is wrong with the #1 counter weight? I see one hole that looks REALLY deep and another spot that looks like it was damaged.
Old Oct 13, 2012 | 05:44 PM
Olds_71_442's Avatar
Yeah.....the bottom hole looks like someone tried to drill it with a hand drill. The top looks like someone hit it with a hammer and chisel.
Old Oct 13, 2012 | 05:59 PM
oldstata's Avatar
Justin
Too me it looks like they melted it and one hole looks like the added metal if the makes any sense
Old Oct 13, 2012 | 06:02 PM
oldstata's Avatar
Justin
I thought they did it to balance but I don't know much about internals build up very well
Old Oct 13, 2012 | 06:21 PM
RetroRanger's Avatar
72 Olds CS
hey old stata
curiousity question how deep is the dish in those pistons in mm or inches ? its hard to tell from the pics
Old Oct 13, 2012 | 06:26 PM
oldstata's Avatar
Justin
5/16 of a inch
Old Oct 13, 2012 | 06:36 PM
  #31
72 Olds CS
5/16 of a inch
thats deep
thats about the .320 8.4:1 comp pistons pilot linked to above, I am just tryingto figure what I have....I gotta go run out to the garage now
thanks
Old Oct 13, 2012 | 06:42 PM
  #32
oldstata's Avatar
Justin
I think I might have enough sand to build a castle with my kids it just kept pooring out of the water jackets even a chunk if glass don't know where they went boating but man the must of loved the beach
Old Oct 13, 2012 | 06:52 PM
  #33
ah64pilot's Avatar
That is what they did...the other pictures make it clearer. However, I thought they used a mallory plug...that looks like lead was poured into it. And why it's beat up is new to me...
Maybe Mark will know
Old Oct 13, 2012 | 06:55 PM
  #34
oldstata's Avatar
Justin
Yeah the one that looks beat up looks like lead as well sorry my I phone don't take the best pics it looks like they tryed to smooth it with a stick ?
Over all all the bearings looked good I could still read the ink on them Hopefully the crank and rods are useable Not really sure what pistons to use all the ones I been looking at are expensive 😱
Old Oct 29, 2012 | 07:44 PM
  #35
lemoldsnut's Avatar
That looks like a Mallory Unilite distributor. I can do a few different 455 engines as well. lemoldsnut@aol.com I am in Redmond, Oregon
64 CUTLASS KEN
Dec 7, 2020 06:43 AM
lunaboy
Sep 24, 2018 10:15 AM
69OLDSCUTCONV
Nov 18, 2011 06:53 PM
DarkStar
Oct 21, 2009 07:35 AM
