Headers for a 70 cutlass supreme convertible
Welcome to Classic Olds. Its a myth. The only problem that I can see is you may have to relocate your brake distributor switch assembly. Do you have a column shifter? If so, the headers may interfere it. Good luck.
The convertible frame is boxed but I don't believe there is any additional bracing. Nobody knows where that myth came from but it has been around a long time. From the firewall forward the Cutlasses are all the same.
TOONLOVESCHERYL
April 7th, 2011 10:38 AM
