Headers for a 70 cutlass supreme convertible
Old Apr 18, 2018 | 07:24 PM
Davew's Avatar
help!
has anyone installed headers on a 1970 cutlass supreme convertible? Hedman makes a set for cutlass supreme’s, but not for a CS convertible. Any help?
Old Apr 18, 2018 | 07:40 PM
ELY442's Avatar
Welcome to Classic Olds. Its a myth. The only problem that I can see is you may have to relocate your brake distributor switch assembly. Do you have a column shifter? If so, the headers may interfere it. Good luck.
Old Apr 18, 2018 | 07:46 PM
Davew's Avatar
Thank you. It has a center console shift.
is there any additional bracing in the frame for a convertible? I thought that may be the problem.
4speed455's Avatar
I have Hooker Headers comp 3902 on my 70 Cutlass Supreme Converitble with a 455. The fit is good with the only slight mods required.
Old Apr 18, 2018 | 08:50 PM
redoldsman's Avatar
Proud Viet Nam Veteran
The convertible frame is boxed but I don't believe there is any additional bracing. Nobody knows where that myth came from but it has been around a long time. From the firewall forward the Cutlasses are all the same.
Trebla781
Jul 9, 2014 06:54 PM
Mitchgrab08
Oct 19, 2013 08:35 AM
Wyze
Mar 18, 2012 01:59 PM
TOONLOVESCHERYL
Apr 7, 2011 10:38 AM
bigcaser
Jul 22, 2004 12:28 PM
