Old member been away for a while
Old Nov 13, 2018 | 08:48 PM
miked's Avatar
This is actually a re-introduction as I have been a member here for several years. I thought when I retired I would have plenty of time to finish my project but with all the honey-dos I had put off and then life getting in the way I have not made much progress. To summarize, I have a 67 442, 4spd, 3.91 posi. with a decent running G block. Tho I don't know it's history the engine is solid, good oil pressure, no smoke and very clean looking under the rocker covers so I assume it was rebuilt before I got it. Previous owner(s) had added Hookers, Edelbrock OBII with 650 Holley, and hei. I restored it as 'owner installed' track pack using an original air shroud I had saved for over 40 yrs. I have a rebuilt E block ready to install. I will be going back stock on intake/quadrajet and ignition and Gardner exhaust. Also plan to upgrade to disc brakes so I will be asking a lot of questions of you guys. OK time to get busy and back on track!
Old Nov 14, 2018 | 08:26 AM
don71's Avatar
same but different
I can understand about not enough time. It sounds like you've got a sound plan and really good car to change up to your liking. Good Luck and welcome...back.
Old Nov 14, 2018 | 08:33 AM
2blu442's Avatar
Welcome back Mike!
Old Nov 14, 2018 | 09:28 AM
miked's Avatar
Thanks for the welcome back....got a lot of catching up to do
Old Nov 14, 2018 | 12:04 PM
Oldsmaniac's Avatar
Was wondering where you went....
Old Nov 14, 2018 | 12:17 PM
CRUZN 66's Avatar
Olds Fever
Welcome back to the world of Oldsmobile... I also have a 67 on the back burner due to other priority issues over the years... Good luck with your project...
Old Nov 16, 2018 | 06:40 PM
Welcome back, I found that I'm more busy since retiring.
w30rocks
Aug 4, 2014 11:13 AM
Theron Woodward
Jul 10, 2013 01:29 PM
krooser
May 30, 2013 02:25 PM
7olds1
Dec 28, 2012 04:55 AM
88Rebelrodder88
Nov 10, 2012 12:11 PM
