Newbie introduction
Newbie introduction
I just bought 1965 f-85 4dr from my son. Has original 330cu in. w/ brocken rocker arm. In hunt for parts. This is my first olds. Hope to find parts so I can have a number matching car. Plan to to a complete resto if so. Any advice would be appriciated. ThanX Jimmison2009
Welcome to the site. Someone familiar with the 330 will chime in with the part or point you in the right direction. It helps if you post your location that way someone close might have what you need
Welcome aboard
2blu442 will help you out if he can , like a lot of the guys on this site he is very helpful. Getting the used version would be cheaper of course but you should check it out good cause you may need other things. The good part is that Washington and Oregon are not far apart.
2blu442 is a stand up guy and will give you a good deal on the parts you need. I have bought from him as have many others on the site and parts are not the heavy so the postage should not be the high. Good luck and keep us posted on your progress
Thanks wmachine. In early 1964 the 330's were made with the old shaft style rocker arms which were cast. In the middle of the production year GM changed to stamped pedistal type. So I'm hopin' somebody does have the right part. if blu442 has 1965 330 they are stamped.
Hello Jim
Is this the style of rockers you need? If so, I'll pull the bridges in the next couple evenings, clean them up then pick out the best one to photograph for you. They look rusty, but it's a powdery stuff that I could wipe off with my fingers so until I wash them off with solvent I'm not sure what it's done to the metal. John
Morning 2blu442, that would be type 2, I need type one, which has a horizonal shaft that goes through all 8 rockers. The head will have a #1 on it. they discontinued type on in the middle of the 1964 production year. I will try to post a pic of it this evening. ThanX
Hello Jim
Here is a pic of what it looks like.
http://picasaweb.google.com/jimmison...81797960629474 this should work
Last edited by jimmison2009; June 25th, 2009 at 02:46 PM. Reason: http wasn't right
