New here
Old Mar 21, 2026 | 03:09 PM
Eboho's Avatar
New here
I am restoring a 71 Cutlass S in my basement garage to be a nice driver. I am doing it on weekends and as I have time during the week so its a slow process. It runs and moves so I am lucky in that aspect. This car has never been touched or tinkered with, just about everything is original. I will get pics as I can.
I do have a question, I will need new carpeting for it. This is an automatic car with a center console. When looking at carpet it will say manual w/console or automatic. Do I assume the "automatic" is column shift or console? I assume the difference is the trans tunnel. Is the trans tunnel the same for both with a console? Its not a manual but it has a console. Any help is appreciated. Thanks.
Old Mar 21, 2026 | 04:00 PM
Nearly all classic Oldsmobile carpet is drop-shipped from ACC. I ordered my '71 CS convertible carpet from Legendary Auto Interiors & it was drop-shipped from ACC. I took the liberty of loading up a 1971 Cutlass into the ACC on-line product tool which demonstrates the auto loop carpet (OEM) will fit with or without console.
ACC 1971 Cutlass
Old Mar 21, 2026 | 04:18 PM
Eboho's Avatar
Ok, thanks a ton. So I wonder why they make the differentiation between the two. I thought maybe since the carpets are molded they were different.
Go with the mass backing also I assume?
Old Mar 21, 2026 | 04:48 PM
You'll note variations in on-line statements by most of the vehicle carpet manufacturers. I can't speak directly to 'why' they differentiate on one site vs. another site.
I think this is the Legendary Auto Interior on-line web site for your car (below)??
Here's another recent thread while there are many threads on this site regarding carpet if you perform a Search. Some w/ more pleasant commentary than others.
I went w/ mass backing w/ no issues. I believe backing is a user preference. Good Luck.
I'll say this if you call Legendary Auto Interiors they have excellent customer service very willing to assist on the phone. (800) 363 - 8804
New carpeting
1971 Oldsmobile Cutlass-S
Old Mar 21, 2026 | 04:53 PM
Eboho's Avatar
Thanks Norm, I am going to order from them. They have the correct bucket seat covers I need so it will be a big order from them lul
Old Mar 21, 2026 | 04:54 PM
Click on the 'SAMPLES' breadcrumb on the Legendary website to view the GM Auto color samples.
https://www.legendaryautointeriors.c...sample-request
Old Mar 21, 2026 | 04:55 PM
You're quite welcome. Good Luck.
Old Mar 21, 2026 | 07:40 PM
rocketraider's Avatar
Oldsdruid
A stick floorshift car is going to have a "hump" on driver side of the transmission tunnel to clear the floor shifter linkage rods. Carpet should be heat-molded to fit over the "hump".
An automatic floorshift car doesn't need the "hump" as the shifter cable routes through a hole and grommet on the tunnel.
Sometimes carpet for a console car comes with a section cut out over the tunnel. Mainly to avoid interference between carpet and console parts.
Good luck with the car.
Old Mar 21, 2026 | 07:54 PM
Eboho's Avatar
Thanks, that explains it ...any automatic will be the same.
Old Mar 22, 2026 | 04:18 AM
Welcome, make sure you post pics of your Oldsmobile.
Old Mar 22, 2026 | 06:12 AM
Eboho's Avatar
This is it the day after it was delivered.
I have the front end apart now and am very close to getting it buttoned up to start on the rear. Power driver seat still works!!
Old Mar 22, 2026 | 07:22 AM
Excellent!
You can get carpet here.
https://www.automotiveinteriors.com/default.asp
I ordered a set of seat covers for my 86 Ford F250 from them. They have good customer service and decent prices.
Old Mar 22, 2026 | 07:41 AM
67OAI's Avatar
Old(s)GuysRule
Welcome aboard! Nice to see another Olds being saved!
abody
Nov 4, 2025 02:53 PM
Falkon
Aug 14, 2022 11:36 AM
Montana1969-442
Mar 5, 2013 02:09 PM
Jan 25, 2013 01:01 AM
jasm8
Aug 14, 2011 05:32 AM
