94 bravada turned mudding
Old Oct 21, 2016 | 11:18 AM
Braeven's Avatar
So im I'm looking for good suggestions on how to make it true 4wd and if anyone has ideas that will help in the long run just let me know oh also abs delete how to go about that
Old Oct 22, 2016 | 05:27 AM
I think what most of the folks in the off-road crowd would do is remove the Bravada body and put it on a Chevy Blazer frame. Apparently, there are plenty of 4wd aftermarket parts for the Blazer and practically nothing for the Bravada. Not to say you couldn't take the Bravada off-road as is. I suggest you get hooked up with a local off-road club and do some mudding before you start throwing money and parts at your Bravada.
Old Oct 22, 2016 | 08:57 AM
The Bravada and Blazer use the same frame. Swapping would be a big waste of time. The difference is in the transfer case. Olds used an AWD transfer case with an actively controlled center differential. Swap that for a manual transfer case from a Chebby.
Old Oct 22, 2016 | 10:20 AM
jcdynamic88's Avatar
if my memory serves me right the 94 and older bravada is always in 4wd,transfer case and front differential,there weren't any controls until 95 ,no low range either.as for abs you can just unplug the abs motor under the hood,driver's side.
Old Oct 22, 2016 | 10:25 AM
Without controls, the center differential is not locking. This is like an open (non posi) rear axle. I suspect the OP wants a locked center diff for mudding. The Bravada transfer case won't do that, which is why I said swap the transfer case.
Old Oct 22, 2016 | 04:03 PM
Braeven's Avatar
Ty vm for the help y'all have g8ven me
Old Oct 24, 2016 | 05:43 AM
The real Chevy Blazer, the K5. Not that late model make believe stuff.
Old Oct 24, 2016 | 08:43 AM
JMO, without changing the power train to something a bit more stout and adding more power, I see no reason to pursue making the Bravada a serious off road warrior.
Old Oct 24, 2016 | 09:56 AM
Braeven's Avatar
It's a newer 4.3 vortex motor and plan on doing a treanfercase swap also maybe a transmission swap for true 4x4 9nly prayed 675 for the bravada bravado and runs grate so why not out a little in and have fun
Old Oct 24, 2016 | 03:32 PM
Go play, just be prepared for broken parts and an occasional tow if you really push it.
jensenracing77
Jun 14, 2012 07:14 PM
sammy
Feb 7, 2012 07:36 PM
rocketraider
Dec 15, 2011 01:57 PM
Svinet
Jun 15, 2010 11:09 AM
Threejdsolds
Mar 30, 2009 07:57 AM
