71 Cutlass Solenoid wire routing
Hi, I have a 71 Old Cutlass 350 with TH350 Trans I am restoring. I am installing a new wiring harness. Can anyone tell me how the starter solenoid wires are routed, (where)? Pictures helpful !, Thanks !
Welcome aboard.
Best thing to have is a 71 Cutlass Assembly Manual, and an Oldsmobile Chassis Service Manual (CSM). Both are available relatively inexpensive on the web. They have good pics of what you're looking for.
examples:
http://www.ebay.com/itm/1971-Oldsmob...item2c950185ad
http://www.ebay.co.uk/itm/1971-Oldsm...-/390085813433
You can also ask for them to be shipped at 'book rate' which will save a bit of $$$.
examples:
I don't know if this is stock or not but this is what I did with mine.
1. Wires come off the starter (heat shield sleeves) and split; battery wire through the tube, the others run behind the tube.
[IMG][/IMG]
2. Then it runs up, behind the brake booster.
[IMG][/IMG]
3.Then it meets up with the rest of the harness.
[IMG][/IMG]
Hope this helps. Like I said, I don't know if this is stock but mine was a mess when I bought the car.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
