71 Cutlass Solenoid wire routing
Old Jan 17, 2015 | 07:21 PM
rus944133@outlook.com's Avatar
Rnds 71 Cutlass
Hi, I have a 71 Old Cutlass 350 with TH350 Trans I am restoring. I am installing a new wiring harness. Can anyone tell me how the starter solenoid wires are routed, (where)? Pictures helpful !, Thanks !
Old Jan 17, 2015 | 09:06 PM
Welcome aboard.
Best thing to have is a 71 Cutlass Assembly Manual, and an Oldsmobile Chassis Service Manual (CSM). Both are available relatively inexpensive on the web. They have good pics of what you're looking for.
examples:
http://www.ebay.com/itm/1971-Oldsmob...item2c950185ad
http://www.ebay.co.uk/itm/1971-Oldsm...-/390085813433
You can also ask for them to be shipped at 'book rate' which will save a bit of $$$.
Old Jan 17, 2015 | 10:14 PM
Macadoo's Avatar
I don't know if this is stock or not but this is what I did with mine.
1. Wires come off the starter (heat shield sleeves) and split; battery wire through the tube, the others run behind the tube.
[IMG][/IMG]
2. Then it runs up, behind the brake booster.
[IMG][/IMG]
3.Then it meets up with the rest of the harness.
[IMG][/IMG]
Hope this helps. Like I said, I don't know if this is stock but mine was a mess when I bought the car.
Old Jan 19, 2015 | 12:14 PM
Rnds 71 Cutlass
Thanks for the help !Looks like a good idea to use heat shield wire jackets on the cabling near the manifold & starter
Old Jan 19, 2015 | 12:15 PM
Rnds 71 Cutlass
Thanks ! I have the Cutlass Chassis Manual, but did not know about the 71 assembly manual.
Old Jan 20, 2015 | 04:32 AM
Macadoo's Avatar
If you haven't already, you can download the assembly manual from wildaboutcars.com. It's a little hard to read but works okay.
Old Jan 20, 2015 | 08:44 PM
Mac, actually it's no longer Wild About Cars and it's no longer free.
Old Jan 21, 2015 | 04:31 AM
Macadoo's Avatar
No kidding? When did that happen? I guess I'm lucky I saved them to my hard drive.
Old Jan 21, 2015 | 10:37 AM
Months ago! Here's a link to the thread that explains it from the head honcho himself.
Old Jan 21, 2015 | 03:37 PM
Macadoo's Avatar
Ahh, okay. That's quite a read. Can't say I blame them though.
GM MUSCLE
May 8, 2015 04:50 PM
tcarroll
Sep 14, 2014 09:03 AM
pogo69
Hurst/Olds
Jan 27, 2013 11:50 AM
idaholc
Jan 6, 2011 12:13 PM
Rocketbrian
Dec 29, 2010 02:23 PM
