"R" terminal yellow wire on starter solenoid with HEI
Hi Olds people,
I have a 1967 442 with a 400 cid 4 speed. I am replacing an old HEI distributor with a new one. I found the old yellow lead that used to go to the points type coil just taped in the factory harness. My question is on the starter solenoid, do I still need to hook up the yellow lead to the "R" terminal or just delete it? It is hooked up, but wasn't this just to supply 12 volts to the old points coil? The only problem I have had is when going to crank the engine, the starter would spin but not kick out the drive until a few tries. So I was going to replace the starter solenoid but it looks new?
Thanks...
Thanks...
joepenoso
Jun 4, 2014 01:56 PM
|-K|=K
Sep 29, 2009 09:56 AM
