"R" terminal yellow wire on starter solenoid with HEI
Old May 8, 2015 | 09:55 AM
GM MUSCLE's Avatar
Hi Olds people,
I have a 1967 442 with a 400 cid 4 speed. I am replacing an old HEI distributor with a new one. I found the old yellow lead that used to go to the points type coil just taped in the factory harness. My question is on the starter solenoid, do I still need to hook up the yellow lead to the "R" terminal or just delete it? It is hooked up, but wasn't this just to supply 12 volts to the old points coil? The only problem I have had is when going to crank the engine, the starter would spin but not kick out the drive until a few tries. So I was going to replace the starter solenoid but it looks new?
Thanks...
Old May 8, 2015 | 10:29 AM
Oldsmaniac's Avatar
The yellow wire is not needed as it provides 12v to the coil while cranking and with HEI not needed. You only need the purple wire to activate solenoid.
Old May 8, 2015 | 11:02 AM
You may need that 12v wire from the starter if the ignition is not providing a 12v in the start position of the key switch. Your starter issue may be the starter drive.
Old May 8, 2015 | 02:50 PM
GM MUSCLE's Avatar
Thank You So Much! I appreciate it!
Augie
Old May 8, 2015 | 02:52 PM
GM MUSCLE's Avatar
Thanks! I will try a new drive. It makes sense.
Old May 8, 2015 | 04:05 PM
Octania's Avatar
or, solenoid contacts welding themselves together
Old May 8, 2015 | 04:50 PM
There's no harm in connecting the yellow wire to the HEI hot terminal, but you don't absolutely need it either.
tcarroll
Sep 14, 2014 09:03 AM
joepenoso
Jun 4, 2014 01:56 PM
hawks70
Jun 15, 2013 10:03 AM
pogo69
Hurst/Olds
Jan 27, 2013 11:50 AM
|-K|=K
Sep 29, 2009 09:56 AM
