Part 2, bought a 65 442 Club Coupe
Old November 22nd, 2012, 02:56 PM
  #81
Justin
oldstata's Avatar
Looks pretty good hope that hood is a spare/ practice one that could be a lot of extra sanding 😃
oldstata is offline
Old November 22nd, 2012, 04:50 PM
  #82
TK-65's Avatar
Nothing some paint stripper wont fix.
TK-65 is offline
Old November 22nd, 2012, 06:56 PM
  #83
Registered Luser
ent72olds's Avatar
Jasen, awesome work so far! Really looking forward to more of this build....
ent72olds is offline
Old November 22nd, 2012, 08:09 PM
  #84
72 Olds CS
RetroRanger's Avatar
nice details like reapplying the original stickers everything is looking great.
also thanks for showing how you straightened out the dash that will look good when its all together
is this the gibbs brand you used ? That will prevent rusting on bare metal ?
RetroRanger is offline
Old November 23rd, 2012, 05:47 AM
  #85
TK-65's Avatar
Yes Gibbs Brand. I found a can on my old mans shelf. He used it to try to free up an old Caddy engine. You have to reapply it every so often to keep the metal saturated. But from what Ive read guys have put it on wheels and 5 years later they are still nice.
TK-65 is offline
Old November 23rd, 2012, 12:25 PM
  #86
TK-65's Avatar
60 degrees yesterday and 40s with snow today. Had to spray the bottom today so I fired up the heater and did my best. Ran it directly on the frame to get some heat into the metal. Frame is now completely primed, kinda wish this was the final coat. Color matches damn well.
TK-65 is offline
Old November 23rd, 2012, 01:46 PM
  #87
11.52 @116
jims2000lt's Avatar
Cool project. Very nice finished 65. I have the MCR issue with it and a ton of Oldsmobiles in it, set aside.
jims2000lt is offline
Old December 17th, 2012, 04:13 PM
  #88
TK-65's Avatar
Had the front backing plates replated in silver zinc. Got them back today.
TK-65 is offline
Old December 17th, 2012, 04:47 PM
  #89
therobski's Avatar
That frame is sweet. I think If I could do it all over again I would have sourced another frame for 64.
therobski is offline
Old January 25th, 2013, 01:20 PM
  #90
TK-65's Avatar
Finished up the front brakes, well theyre not on the frame yet but close enough.
Before..
After..
TK-65 is offline
Old January 26th, 2013, 03:19 PM
  #91
a64olz's Avatar
Those brakes are too nice to put on a car, I would hang em on my living room wall.
a64olz is offline
Old February 2nd, 2013, 09:39 AM
  #92
TK-65's Avatar
Original alternator worked great but as I found when I took it off, the upper mounting ear was broke. Figured it was scrap but Ken Bruno, who restores alternators, said it wouldnt be a problem to fix. He tig welded and machined it back to normal. Cant tell it was ever broken.
TK-65 is offline
Old February 2nd, 2013, 02:46 PM
  #93
F-85 4-4-2's Avatar
That is nice!
F-85 4-4-2 is offline
Old June 7th, 2013, 01:38 PM
  #94
TK-65's Avatar
Small things starting to add up. Not much more I can do before getting to the bigger things like bodywork and paint. Maybe start on the rear end and drive shaft.
TK-65 is offline
Old June 8th, 2013, 02:59 PM
  #95
charlierogers's Avatar
very nice on the detail work! the smalls are a real money killer.
Charlie,,,
charlierogers is offline
Old June 18th, 2013, 02:17 PM
  #96
TK-65's Avatar
TK-65 is offline
Old October 13th, 2013, 09:36 AM
  #97
TK-65's Avatar
Painted the frame and started putting the suspension back on this week.
TK-65 is offline
Old October 13th, 2013, 10:04 AM
  #98
Looks nice!
oldcutlass is online now
Old October 13th, 2013, 01:02 PM
  #99
Dave Siltman's Avatar
Hey Jasen, Everything is looking great!!! You have a real talent there my friend, and I am always eager to see any progress updates. Have you started the body work? Any final color decisions? I know the "guts" will be red, but what about outside? Any chance of a two-tone?
Dave Siltman is offline
Old October 13th, 2013, 02:45 PM
  #100
wow, its really coming together great. looking forward to more pics as they come.
Charlie,,,
Old October 13th, 2013, 04:33 PM
  #101
TK-65's Avatar
Thanks guys. Got the drums painted today. After 50 years good drums are hard to find. Might have to stock up on them for the future.
TK-65 is offline
Old October 13th, 2013, 05:56 PM
  #102
Paladin31's Avatar
Thumbs up Awesome project
Your progress is nearly as quick as the photo shift in your signature icon...WOW! Damn sharp work sir. I'd wish you good luck but it appears you already have it all . Brett
Paladin31 is offline
Old October 18th, 2013, 08:12 PM
  #103
TK-65's Avatar
Got the springs installed, what a pain in the ***. Drivers side took all afternoon, first spring compressor wouldnt come out after the I put the spring in. Second one wouldnt compress it enough. It took 6 45lb plates, some tires, a head, and myself to get it far enough into the ball joint to start the nut. Nicked up the control arm and the spring pretty good. Other side took 5 minutes, no nicks at all. Must have been the all day practice on the other side.
TK-65 is offline
Old October 19th, 2013, 09:50 PM
  #104
Ben
RAMBOW's Avatar
Sure looks nice!
Little tip for you, next time around-
Try to only use the upper half of the compressor, and thread the rod DOWN through the upper shock hole, and use the compressor to pull the spring up into the frame socket.
Works like a charm, and you don't have to look for heavy things to put on the car to give it weight if the engines out- or fight with getting the upper and lower set of compressor fingers to stay put while you tighten it up.
RAMBOW is offline
Old October 26th, 2013, 04:37 PM
  #105
TK-65's Avatar
Originally Posted by RAMBOW
Sure looks nice!
After I read this I went out and tried it, just for future reference. The rod was too big for the shock stud hole.
Got the drums on the front. Moving on to the rear end now. Will be much easier to move around once I get it rolling again.
Decals are ultra-high-compression.com exclusives.
Rear end waiting for a new posi and new paint.
TK-65 is offline
Old October 26th, 2013, 07:19 PM
  #106
Old School Olds
tru-blue 442's Avatar
Very nice work!
tru-blue 442 is online now
Old October 27th, 2013, 07:55 AM
  #107
442scotty's Avatar
Awesome work as always. It has to be time consuming! Where do you find the time what with a wife and kids!
442scotty is offline
Old October 27th, 2013, 08:27 AM
  #108
TK-65's Avatar
Mostly work at night after the kids have went to bed. My wife doesnt mind too much now, back when I did the other one it wasnt as easy.
TK-65 is offline
Old October 27th, 2013, 09:34 AM
  #109
Justin
oldstata's Avatar
What are your plans with the gas tank are you going new and keeping the stainless look or are you going to paint it ?
Thanks just trying to get some ideas
oldstata is offline
Old November 10th, 2013, 06:40 PM
  #110
TK-65's Avatar
Fuel line and brake lines installed.
Clips came painted red, but originally they were green phosphate. Ordered a can of Moeller Zinc Chromate primer off Amazon to make them correct.
Rear upper arms are on, stamped PONT.
Lower arms are nice used Pontiac Tempest arms I got from Franks Pontiac parts out in California. Unboxed with no holes for a sway bar. I had to drill the holes to make them work. Thats after they received new bushings. The burn method worked great for getting the rubber insert out. Need to get the boxed inserts welded it then I can paint them.
Rear backing plates are cleaned and painted, ready for brakes.
TK-65 is offline
Old November 10th, 2013, 07:10 PM
  #111
Shoveling Snow
Hairy Olds's Avatar
Wink
The brake and fuel lines look great. Did you get them from inline?
Hairy Olds is online now
Old November 10th, 2013, 07:29 PM
  #112
TK-65's Avatar
yes. Took two weeks and three phone calls before they shipped them. Thought they might have red flagged me.
TK-65 is offline
Old November 10th, 2013, 08:10 PM
  #113
just checking up on your thread and had to laugh a little about the pain in the butt front spring install. it reminded me of the front springs I just put in my 57 chevy. they were about 5 inches taller than the stockers to get the nose up in the air {gasser look} that was a real party!!! anyway the chassis looks top notch. btw are the ball joints ILT with the look alike rivits?
Old November 11th, 2013, 04:42 PM
  #114
TK-65's Avatar
Parts Place. Inline rivet bolts are not even close to looking right. They made them to look like the underside of the rivet (flat) instead of the top.
TK-65 is offline
Old November 14th, 2013, 11:26 AM
  #115
TK-65's Avatar
Rear brakes on. Next stop the rear end.
TK-65 is offline
Old November 14th, 2013, 12:14 PM
  #116
Shoveling Snow
Hairy Olds's Avatar
Hows come when you restore a car it looks nothing like the cars on Wheeler Dealer?
Old February 1st, 2014, 08:37 AM
  #117
TK-65's Avatar
Sent out the steering gear to Chip @ Powersteering.com Looks perfect and should perform as new. He also restored the Pittman arm and the not reproduced manual rag joint for free. Box is dated A3574, first shift December 23rd 1964.
TK-65 is offline
Old February 1st, 2014, 08:43 AM
  #118
TK-65's Avatar
Cleaned and primed the rear end. Bought a 3.90 posi set for it and hope to get it installed this week. Once the gear is in Ill paint the housing. No use painting it then having the axle shop scrape it up on the workbench.
TK-65 is offline
Old July 20th, 2015, 02:21 PM
  #119
TK-65's Avatar
TK-65 is offline
Old July 20th, 2015, 05:58 PM
  #120
Kjr442
kjr442's Avatar
Sure is nice Jason. Lots of hard work.
kjr442 is offline
66trakpak
Cars Wanted
August 17th, 2019 05:21 PM
ALBENINC
November 12th, 2011 03:04 PM
Rickman48
September 23rd, 2010 03:15 AM
66trakpak
September 11th, 2010 03:50 PM
TK-65
August 14th, 2010 07:35 PM
Quick Reply: Part 2, bought a 65 442 Club Coupe
