Vista Body on Rotiseri
Old Oct 20, 2012 | 06:49 PM
  #281
70vista's Avatar
I don't think the vista axles are different from the the other "O" types are but will look at the other 3.42 12 bolt "O" I have.
Originally Posted by Allan R
Thanks Steve. I'm a little late for that so I'm wire wheeling and sanding. Taped off the oil seal and bearings to avoid dust. I was also thinking of metal cast finish. I notice your axles have only 3 holes and my 72 has 4. Is that a VC feature?
Old Oct 20, 2012 | 08:10 PM
  #282
This is what I mean. This is before I popped the studs and cleaned it up, but it is an O axle.
Old Oct 21, 2012 | 05:11 PM
  #283
70vista's Avatar
I have never seen that hole pattern on the "O" types I have. They all have the 3 hole pattern.
Old Oct 21, 2012 | 05:22 PM
  #284
70vista's Avatar
Hi, Made some more progress on the Vista this weekend. Got the bumpers assembled, fitted the chrome radiator hoses and wired the ignition. I an close to starting it but may wait till spring because I will ru water at first until I know there are no leaks. Here are some bumper pics.
Does anyone see any problems with running dex-cool vrs the typical green glycol? for coolant??
Old Oct 21, 2012 | 06:46 PM
  #285
ent72olds's Avatar
Registered Luser
Beautiful Steve! What did you end up doing with the rubber pad that goes on top of the rear bumper? Still wondering what to do when I get to that point!
Old Oct 21, 2012 | 10:07 PM
  #286
oldsguybry's Avatar
NOVICE car nut
I know Dexcool was a big problem with the early 2000 cars , but I believe it was because of the cheap gaskets .
Old Oct 22, 2012 | 09:38 AM
  #287
70vista's Avatar
I have not decided yet. I may have to come up with somthing on my own. I would probably use the steele from the old ones and add a liner type material from a place like home depot.
Old Oct 22, 2012 | 05:44 PM
  #288
ent72olds's Avatar
Registered Luser
Allan(bluevista) had found someone repro-ing these....he had mentioned it in a thread.....I'll have to find it! Will keep you posted if I find anything...
Old Oct 22, 2012 | 06:39 PM
  #289
70vista's Avatar
EINSTYN is the company he is thinking of? They are working on repros but not done yet.
Old Dec 1, 2012 | 01:47 PM
  #290
70vista's Avatar
Little update on the project. I have all the door glass back in, gate glass in and working, sport mirrors on, all the stainless trim on the sides and the front and rear bumpers. Here are some pics as of today. I am starting on the inside more now.
Old Dec 1, 2012 | 03:34 PM
  #291
ctsplicer's Avatar
I gotta say,I really like that paint scheme
Old Dec 1, 2012 | 06:15 PM
  #292
ent72olds's Avatar
Registered Luser
Steve, are you trying to tease us by leaving the raggy wheels and tires?
Old Dec 2, 2012 | 06:20 AM
  #293
HWYSTR455's Avatar
Dex-Cool is now fully backward compatible, or that's my understanding.
I coated the back side of my bumpers with undercoating, helps prevent it from rusting where they usually don't pay close attention to the plating. Once the flaking starts, it can reach the edge, and start attacking the visible area. This is important especially if you drop boats in the water off ramps. I've seen some use truck bed liner stuff too. Realize it's too late, but figured I'd mention anyway.
Old Dec 16, 2012 | 11:59 AM
  #294
70vista's Avatar
Thnaks for the info HWYSTR455. I made some more progress the las couple of weeks. Installed the small mldgs that break off the tu-tone.installed the glove box and rally pac which seems to work as far as I can tell without starting the car and put fatmat on the floor. Here are the pics.
Old Dec 16, 2012 | 05:50 PM
  #295
Really nice. Thanks for sharing.
Old Dec 19, 2012 | 04:46 PM
  #296
darinstreaks's Avatar
That is a beautiful paint scheme, Steve!
Old Dec 20, 2012 | 07:14 AM
  #297
oldsguybry's Avatar
NOVICE car nut
Man , that car is going to shine ! Beautiful wagon !
Old Dec 20, 2012 | 10:33 AM
  #298
70vista's Avatar
Thanks for the positive comments guys. I am starting see a dim light at the end of the tunnel. Steve
Old Dec 21, 2012 | 04:08 PM
  #299
70vista's Avatar
Got the rug out of the box and laid it out on the floor. It looks like it is short at the rear outer corners where the back seat bolts down. I will have to have a piece sewn on. The last pic is of how much fatmat I had left out of a 33'X18" roll. Cut it pretty close. LOL
Old Jan 12, 2013 | 01:21 PM
  #300
70vista's Avatar
Was able to get back on this project after the holidays and got the anodized aluminum window trim back from the polisher. I did not have them reanodized and will have to polish them now and then but they came out great. Here is a couple of shots of the trim. Steve
Old Jan 12, 2013 | 02:57 PM
  #301
oldsguybry's Avatar
NOVICE car nut
That really looks excellent !
Old Jan 12, 2013 | 06:16 PM
  #302
toms vista's Avatar
Looks great ! I currently have mine in the body shop and about 1 month or so from paint . All the window channels are done as are the rear quarters . The W-30 hood needs some work though. (I wish the Thortons were around when I bought this OE hood) I AM IN NEED OF THE DRIVER SIDE TINTED ROOF GLASS if you know of any . I do have one to fill the hole , however it will more than likely get painted black due to delamination . Any help locating one would be great . Thanks Tom
Old Jan 15, 2013 | 11:06 AM
  #303
billy.bones's Avatar
wow......big like from germany
Old Jan 27, 2013 | 11:40 AM
  #304
70vista's Avatar
I hit a little snag in th project. My oil furnace won't fire. I am guesing the fuel may be gelled do to the cold temps the past week. We are expecting a warm up first part of the week so wil see if it fires then. I did get the wrapped steering wheel from my interior guy and told him we ned to get on the rest of my stuff (he has had it over 2 years). Hre are some shos of the assembled wheel.
Sorry Tom no glass to help you out.
Old Mar 3, 2013 | 12:11 PM
  #305
70vista's Avatar
Not much going on with the Vista right now. I am getting the interior trim ready to paint plus waiting for the interior to get done at the upholstery shop. Once the weather gets a little warmer I will get it done. Steve
Old Mar 10, 2013 | 04:25 PM
  #306
70vista's Avatar
I t was nic eout this weekend and was able to get the metal interior trip stripped and primed. Install the steering wheel and cleaned all the plastic trim that has to be painted. Called my interior guy and will have my seats,door trim panels and rear side panels back by mid April. Here are some pics of the progress. Steve
Old Mar 10, 2013 | 05:38 PM
  #307
car_designer's Avatar
The dash looks great.
Old Mar 10, 2013 | 07:40 PM
  #308
OLD SKL 69's Avatar
GM Enthusiast
x2 on the dash, looks very nice!
Old Mar 12, 2013 | 07:30 AM
  #309
oldsguybry's Avatar
NOVICE car nut
x3
Old Mar 12, 2013 | 08:10 AM
  #310
citcapp's Avatar
Absolutely outstanding work
Old Mar 12, 2013 | 02:54 PM
  #311
Wow very nice. Be real careful with those kick panels when you put them in. I have a set and they will break very easily at the part that goes up by the dash- the little u shaped piece that goes around the steel where the door closes. Mine has broke and I had to put a piece of sheet metal bent in a U behind it. The vinyl or plastic or whatever its made of isn't as good as original GM.
Old Mar 12, 2013 | 05:47 PM
  #312
70vista's Avatar
Thanks for the heads up. I have test fit them and they seem less giving than the originals and will be gentle when installing them. Steve
Old Mar 16, 2013 | 05:37 PM
  #313
455Olds's Avatar
Wow, this will probably be one of the nicest Vistas on the planet when done. What a piece of art. Kudos to you man!
Old Jun 25, 2013 | 09:28 AM
  #314
70vista's Avatar
It's been a long time since I updated this project but had a lot of house stuff to do. The car is running and moving on it's own now but still waiting on the interior to be finished. Here are some pics on where it is now. Steve
Old Jun 25, 2013 | 09:41 AM
  #315
HWYSTR455's Avatar
Wow. I am speechless! That looks sooo sweet!
Old Jun 25, 2013 | 09:49 AM
  #316
Vistabrat72's Avatar
Absolutely beautiful, the efforts have so paid off. The color combos work so well together.
Old Jun 25, 2013 | 07:08 PM
  #317
The car looks great in the sun!
Old Jun 25, 2013 | 08:57 PM
  #318
lil_no's Avatar
That's one nice looking cruiser. I like the color scheme, it looks awesome in the sun.
Old Jun 26, 2013 | 07:10 AM
  #319
pcard's Avatar
70 Cutlass SX
Wow - king of the road! Congratulations!
Old Jun 26, 2013 | 08:19 AM
  #320
citcapp's Avatar
Sweet!!!!!!!!!!!!!!!!
