kids helping with project
#321
What do you mean ? I just used what my budy told me too lol he has been a body guy for 40 years I will check to make sure
#322
If you use regular window urethane its too solid and as the metal will see heat cycles the metal will expand at different rate than the urethane. You want something that will add support but flex as much as the steel will so that you don't get those pesky low spots over time. I learned this the hard way on my dads hood of his 77 Pontiac. I used window urethane and I did all the body work and it came out awesome but sure *** hell once the sun started to beat on it and it had little low spots where the urethane was. I noticed it but most people wouldn't. 3m makes a specific expandable urethane foam that is great I started using that for repairs on hoods and doors with impact beams where I had to take out the original urethane and then re place it.
#324
On the door depending how bad you could cut it out just under the chrome trim and reskin the lower section maybe use a nice flat part if metal from a hood it's basically how I patched my rear lower quarter panels.
You never did say if it was a post or non post
#325
Got that big dent out all I need is to clean up the rust holes fill with lead I hate to say it but the hood might get a skim of filler
#326
Okay lots done today lead work on passager side of the hood ran out half way on drivers side.
I really hate blue paint !!! Have most of the top stripped down one spot has bondo not sure how deep sure it will be a easy fix.
#328
Okay the blue bondo monster is almost no more !
Bondo every where I sand geez
More bondo sorry bad pic
The bondo spot on the roof I think will be super easy I can pop the dent out but it tin cans back just alittle hear shrink and I think it will be good to go back panel had had a bunch just going to straighten. The best I can it will be covered any ways
Just have drip rail to strip drivers side jamb and trunk jamb
#330
Where did he score that lol. I keep a eye out all the time for 65 all I see is over priced 64
#331
On the door check with John,(2blu442)
He has been great to deal with. I know he just shipped me some door hinges from a post doors just not sure if he is keeping the door for his Own project or if there beat up or not.
#332
#333
Hammered a few dents out tonight finished up the door jamb area
#335
I did a quick math I have been doing body work for about a year now at let's say 6 hrs a week on average that's about 312 hrs in body work totall I would feel safe to say 400hrs in a finished product I am safe to say a 25k paint job is what I am ending up with lol
#337
#338
Hood just about done
#339
#340
Okay guess nobody knows about they code in the trunk panel odd tho
Any ways
Worked on the rear panel it needed a lot of work. I didn't really get a pic of before, but here is a mid progress
Any ways
#341
Man this car really had a hard life I bet it had 4 big wrecks And a bunch of small ones
#343
Ok two things happened today, the owner came in saw the car gave me alittle crap and he asked what the plan was once done ? I replied drive it . I swear I thought he was going to die with that answer lol
Also finished up the deck panel and stripped the sealer out of the drip rails
#344
Got hood and doors primed today even got a pic if my painter.
#345
Welded up the screw pull holes on the roof from the old school way of pulling dents
#346
Got with my paint rep today, I made my color from water base paint and he is trying to convert over to solvent base. First try the color matched but the metallic didn't so we will see what he brings this week!
Hoping to finish up the body work in two weeks and assemble for block work
#347
Rust bondo when does it end !!!
#348
#349
nice work and quality, its looking really good. and you are moving along in really good time. i cant wait to get back on my olds.. i should have my 60's f100 done enough to start driving in 2 weeks.. then i can get back on my 64 f85, or the 41 gmc... a one man shop with 6 projects makes it seem like nothing ever gets done around here..
![Frown](https://classicoldsmobile.com/forums/images/smilies/frown.gif)
#350
nice work and quality, its looking really good. and you are moving along in really good time. i cant wait to get back on my olds.. i should have my 60's f100 done enough to start driving in 2 weeks.. then i can get back on my 64 f85, or the 41 gmc... a one man shop with 6 projects makes it seem like nothing ever gets done around here..![Frown](https://classicoldsmobile.com/forums/images/smilies/frown.gif)
#351
Glued in window patches and finished body work on rear panel a light skin of filler and good to go
#352
Took a break today and let my little one do the rear brakes on Momma's truck. Did pretty well
#353
Okay just about done with the last of the metal work well the patching part
Just need to clean it up cut out some old and welder her in
All I have left is to fix both front fender lower mounting bolt they were spinning so have to cut weld the nut again
#354
#356
Thanks Eric
I couldn't agree more. this little guy is a gear head and scary good with his motor skills.
Wow really kicked it in the nuts today was trying to finish up do I could primer tomorrow I'm like 3hrs away
I got most of the roof done (well my buddy did ) there is a eye brow front and rear on the right side was driving him nuts
Skimmed back panel almost all blocked out
Cut into fire wall to tac weld the nuts for fender bolts
Hope these help some one
#358
Thanks whiskey runner!
Primer tomorrow !!!!
Spent 3hrs today finishing up corners of the jams and going over ever inch of the car. Well two of us did cleaned all areas and blew out and vacuumed the whole car.
My painter goes on vacation next week so two weeks everything should be jammed and hopefully assemble for block sanding
This has been a blast I am so excited to start assembly processes
#359
#360
Okay must be having some restoration repair withdrawals. I needed a hood hing as the factor rivit had broke, do I ground down a bolt head and placed the bolt in the rivets place put a nut on ground it down plugged welded and as good as new
Now sand blast primer and paint
