kids helping with project
Old Sep 2, 2014 | 03:24 PM
  #401
oldstata's Avatar
Justin
That's a lot of shims, go for the consult.
Here is a good side view
Old Sep 2, 2014 | 04:46 PM
  #402
Was there a repair done at the bottom?
Old Sep 2, 2014 | 04:54 PM
  #403
oldstata's Avatar
Justin
No repair on frame,firewall or fender
The bottom lines up pretty good and the top looks real close it's like it has wide hips lol
Here is a pic before working door and fender now there is only like two bolts holding this on but you can see it still has that gap in the middle
Old Sep 3, 2014 | 06:07 PM
  #404
oldstata's Avatar
Justin
Okay I might be my own demon as I had a broken off bolt on the fender inside the jam area so we welded it up grinded flat and retapped it. Well it was subpost to have wiggle play lol. Okay I have the right fender really close top lines great nice and even but just a tad low on the side body lines so I need to lift up or something, maybe to many shims at the bottom
Old Sep 4, 2014 | 08:30 AM
  #405
oldstata's Avatar
Justin
Some miner modification. I guess this is why assembly before paint is good but really I don't think I could do this twice lol
Old Sep 5, 2014 | 06:51 AM
  #406
oldstata's Avatar
Justin
Okay so here is the right fender I think I need to pull one shim from the bottom and move it to the top and hopefully it won't be to high where it meets the a piller
Old Sep 5, 2014 | 10:43 AM
  #407
I guess the upper pic is an optical illusion, the top ridge looks low.
Old Sep 5, 2014 | 10:49 AM
  #408
oldstata's Avatar
Justin
The fender is low on the cowl side but even on the a piller
Old Sep 5, 2014 | 02:33 PM
  #409
oldstata's Avatar
Justin
Okay right fender is done
As you can see we started to block sand the roof
I ended up taking two shims from the bottom and added one to the top
Old Sep 5, 2014 | 03:34 PM
  #410
That looks awesome from here.
Old Sep 5, 2014 | 03:51 PM
  #411
oldstata's Avatar
Justin
Here is the left I had to modifie this fender I really don't like the gaps but it's not terrible.
Old Sep 6, 2014 | 11:12 AM
  #412
oldstata's Avatar
Justin
6 hrs block sanding
Old Sep 6, 2014 | 11:20 AM
  #413
oldstata's Avatar
Justin
Right quarter straight as a arrow wow . Well the left needs a little tweaking a few little high spots to fix and we are good to go
Right fender perfect !
Alittle in right door
Well I thought I got a pic if the left side marked up but guess I didn't
Old Sep 8, 2014 | 04:45 PM
  #414
oldstata's Avatar
Justin
Look what scored lol picked from a 65 Chevelle
It's just a cool factor
Old Sep 8, 2014 | 05:10 PM
  #415
Looking great and cool plate!
Old Sep 10, 2014 | 06:20 PM
  #416
oldstata's Avatar
Justin
Okay we metal finished all the high and low spots
Old Sep 11, 2014 | 11:06 AM
  #417
mighty mouse's Avatar
Looking very nice!
The block sanding is the part I don't like.
Old Sep 11, 2014 | 12:40 PM
  #418
oldstata's Avatar
Justin
Originally Posted by mighty mouse
Looking very nice!
Thanks block sanding wasn't too
Bad at all I was nervous as I want a pretty straight body from lower body line up I decided to keep the factory spot weld on the lower side I stead of skimming it, not looking for a show car just better than factory
I talked my painter in helping me with the block sanding he made it look easy even tho I am positive he was just cleaning up after me lol
Old Sep 12, 2014 | 07:57 AM
  #419
I hear you, I have drivers and then all out cars that sit in the garage. The drivers are a hole more fun.
I am hoping to get back on mine soon, building a rotisserie right now for the body, found plan on line for 12 bucks and I have about $300 in metal, nuts and bolts. I think I will have about 400 in it when I am done.
Old Sep 12, 2014 | 08:41 AM
  #420
oldstata's Avatar
Justin
There was a member who bought two harbor freight engine stands beefed them up and used them I will see if I saved the pics
Old Sep 13, 2014 | 12:32 PM
  #421
oldstata's Avatar
Justin
Spot primed today with any luck we will block sand the areas needed they the week and paint Saturday !
Old Sep 29, 2014 | 06:59 PM
  #422
oldstata's Avatar
Justin
Block sanded the hood need to fix a few low spots
Old Oct 3, 2014 | 04:39 PM
  #423
oldstata's Avatar
Justin
Don't know if we will have time to spray it tomorrow or not
Found more body work deck lid left quarter and hood
Reprinted still need to block again
Old Oct 4, 2014 | 12:12 PM
  #424
oldstata's Avatar
Justin
Okay sanded whole car with 600 wet sanded with 600
She is ready for paint one week from now
Old Oct 4, 2014 | 02:36 PM
  #425
don71's Avatar
same but different
You've come a long way with this. Nice shop to be in to get some work done too.
Did I miss your time line? Are looking to completely be done soon or maybe next spring? Just curious, about those Utah winters
Old Oct 4, 2014 | 02:45 PM
  #426
oldstata's Avatar
Justin
Yes, it's been rainy here so it's been killing me. we should have painted today, we ran out of sand paper it killed me my buddy didn't feel well so we called it a day.
my goal is paint this up coming weekend my goal is spring to be on the road, but between motor rebuild and window seals it might be pushing the budget a bit
Shop is great I think I have surly pushed my limits tho my employer has been great for allowing me to use it after hrs even tho I don't work for the body shop side if the business
Old Oct 10, 2014 | 05:09 PM
  #427
oldstata's Avatar
Justin
They let me paint it in the new booth !! It's inly been up and running for a few weeks now
Old Oct 11, 2014 | 06:59 AM
  #428
oldstata's Avatar
Justin
Not done first coat only
Old Oct 11, 2014 | 08:32 AM
  #429
Hawghead's Avatar
Looking good, not long now.
Scott
Old Oct 11, 2014 | 08:46 AM
  #430
Yesssssssssssssssssss, color! Love it!
Old Oct 11, 2014 | 10:15 AM
  #431
oldstata's Avatar
Justin
A few things need touched up but not bad
Old Oct 11, 2014 | 10:50 AM
  #432
Love the color, the chrome will bring it out even better.
Old Oct 11, 2014 | 11:15 AM
  #433
2blu442's Avatar
Congrats! This is a real milestone in your restoration project
John
Old Oct 11, 2014 | 12:09 PM
  #434
oldstata's Avatar
Justin
Thanks guys !
Omg I about had a heart attack today, so grabbed a few buddy's to check it out and this girl with this Great Dane starts to walk right against it ! Started to ask her to back up and yes guess I was yelling lol.
Old Oct 11, 2014 | 05:14 PM
  #435
Troys Toy 70's Avatar
Once Olds Always Olds
Now that IS something to be Proud of!!! Love the color!!
Old Oct 13, 2014 | 05:42 PM
  #436
oldstata's Avatar
Justin
Thanks guys, I couldn't be happer for me doing most of the metal work this turned out great! my buddy did the quarters and the lead work needed and helped me along my way of metal finishing. I did trade work for the block sanding and I helped with it,also I did trade work for the paint work . I got a screaming deal on the clear as it needed to go back to ppg as of July . A big thanks to the friends that helped me and my dealer ship for allowing me to do all of this there even tho at times it was just in the way.
Here is a pic of her in the trailer
A extra big thanks to John (2blu442) he sold me most of the parts needed and when I was in a bind sent me parts I needed fast also to Shane , JATA , honest Dave , solo and a few others.
Old Jan 1, 2015 | 12:43 PM
  #437
oldstata's Avatar
Justin
Played around with the car today
Where I seamed the quarter was a bad spot right in a mounting screw and I glued it in so I could remove easily if needed at a later date
This is the result I think I can get help putting pressure on it to suck it up just need a hand
Sorry for the crappy pics
Old Jan 1, 2015 | 02:05 PM
  #438
Can't wait to see it all back together. Those small imperfections give it personality, and it gives you a story to tell.
Old Jan 1, 2015 | 02:50 PM
  #439
Macadoo's Avatar
Looking great Justin! I love the color and can't wait to see the chrome and wheels on. You're getting there, man. You're getting there.
Old Jan 1, 2015 | 03:20 PM
  #440
oldstata's Avatar
Justin
Thanks guys, I am getting ready to really start moving the wife gave me a few bucks to play with. I want to get some daynamat so I can put the interior together and start on the weather seals I need to do some paint work on the trim ( the original has two strips painted black ) I am changing that color and painting the grill to match still need to pull motor and clean engine bay, but that will be last I think hopefully the heavens will drop a Bbo in for me lol
