Eddie Hansen's '69 Cutlass Convertible
Old November 14th, 2022, 03:34 PM
  #881
Eddie Hansen's Avatar
Thank you,
Originally Posted by alain
Eddie now you are having fun Looking great
Alain red W-31
fun? Lol um yes it is, actually, need to weld some holes shut and fix some bumps and bruises but hopefully can move further down the road .
Eddie Hansen is offline
Old November 14th, 2022, 03:51 PM
  #882
Actually!!!!
Alain red W-31
Alain with my bizarre (and childish) sense of humor, this is fun!!! Borrow two plastic spoons , and use a sharpie pen at the pub! My wife said the bar maids face was priceless but that I am a child… and to knock it off lol
Old November 14th, 2022, 06:09 PM
  #883
maddoctor's Avatar
Can't wait to meet you my friend, we will have to plan on it next summer! You appear to be a hello of a lot of fun!
maddoctor is offline
Old November 14th, 2022, 06:23 PM
  #884
lol indeed my friend that’ll be great
Old November 14th, 2022, 06:43 PM
  #885
Glad to see you're back at it.
Originally Posted by Eddie Hansen
Razor and stripper
Well I'm seeng a gnarly deck lid but where is the stripper? Need more pics, please.
Party on, dude!
Fun71 is offline
Old November 15th, 2022, 02:34 AM
  #886
alain's Avatar
Like I said Eddie you having fun
Alain red W-31
alain is offline
Old November 15th, 2022, 06:14 AM
  #887
Party on, dude!
ohhhhhh you dirty birdy!! Lol
Thank you for encouragement!!! It’s been a long long road and there is still a ways to go,
  #888
Alain red W-31
indeed sir! Thank you for encouragement!!
Old December 4th, 2022, 01:12 PM
  #889
Moving along
Ok so I am continuing work I have stripped the hood top side will be flipping it to strip underside , my hurst scoop arrived and I’ll be fitting that , gulp lol cutting holes is scary lol, I’m the meantime I needed to either find a new hood tooth or repair the Swiss cheese piece, I decided to try the repair first.
the tooth isn’t sheet metal it’s pot metal which adds to the complexity of the repair. I looked on line and found these specialty rods and flux for pot metal from muggy welding
Old December 4th, 2022, 01:24 PM
  #890
Moving along
So I stripped the paint off and removed all the epoxy filling the holes , man was a bit surprised at all the holes !! Swiss cheese, but I had nothing to lose so I decided to give it a go
Old December 4th, 2022, 01:35 PM
  #891
Well….
I put a piece of ceramic trim tile on the backside and used a clamp to hold it, I used a simple map gas torch , followed the instructions and I previously watched a video on the mfg site, when the flux turns a caramel color I fed the rod in, working the edge first then into the center, when I finished that hole moved onto the next where the holes were close together I closed them all at the same time,
when I was done with that area I moved on to the next I put a wrench on the completed area to act as a heat sink, just in case . It really was pretty easy, and the product works as advertised make sure to use enough material as adding afterwards isn’t really an easy thing
heres the tooth after the repairs a little smoothing with putty and it’s fine, I was happy with the results
Old December 4th, 2022, 01:37 PM
  #892
Not a big deal I thought I would share if you have pot metal that needs repairing these rods melt at 350 and really stuck well to the pot metal, I know there’s guys here who want to save every original piece and perhaps this helps some day
Old December 4th, 2022, 02:42 PM
  #893
scrappie's Avatar
Nice work and good info Eddie. A lot of pot medal trim pieces that may benefit from this procedure also?
scrappie is offline
Old December 4th, 2022, 04:54 PM
  #894
indeed scrappie, that was my main impetus for posting it, there are pieces that are practically unobtanium, they also use this material to fill pits etc , one neat thing is this material will work on dissimilar metals , if you had a broken mounting stud , it would be possible to attach an appropriate threaded rod or reattach the stud
Old December 6th, 2022, 02:20 PM
  #895
More pot metal repair
As I was looking at the tooth I noticed that one corner was missing? Not really seen but still , so I decided to see if I could fix it
first I cleaned up both sides of the piece and cut a small piece of 20 gauge steel in the approximate shape, as a backing plate and to add strength if needed as it’s just sitting out there lol
Old December 6th, 2022, 02:26 PM
  #896
I then put the flux honey over both pieces and used the rod to fill I wasn’t too worried about it as this piece gets painted etc
Rough weld
Flipped it over and put a piece of tile as a heat sink and brazed the back side as well
All cleaned up
Old December 6th, 2022, 02:29 PM
  #897
I hope this helps folks I will say the rod works well and I believe I could plate the substrate if required , if this was a hard to find piece of pot metal trim
Old December 6th, 2022, 03:59 PM
  #898
Rodney
cdrod's Avatar
Nice work Eddie, that turned out well. I didn't know you could weld pot metal.
Rodney
cdrod is offline
Old December 6th, 2022, 04:28 PM
  #899
Rodney
I didn’t either Rod, actually I didn’t even know the front tooth was potmetal!! Anyway I had a bfugly one and nothing to lose lol rods work as claimed
Old December 6th, 2022, 05:35 PM
  #900
Duplicate post
Old March 7th, 2023, 10:41 AM
  #901
Update
Well haven’t been on the site or even the internet much, that’s the bad news the good news is I’ve actually been in the garage, so now a little update,
I have been debating and debating the best way to seal the weld seams from the quarter replacement , so I went back over the welds again this time with a tig welder ( there’s a learning curve fellas lol ) but I love it, then I decided to seal the seam with non lead body solder , I really didn’t want to put heat to the panel but I truly believe it’s the best way.
I started by conditioning the trunk and back side of welds and cleaning up that whole area for epoxy primer
Old March 7th, 2023, 10:45 AM
  #902
Cincinnati Rick's Avatar
Wow, that looks like a ton or work, but the results look amazing. Very impressive Eddie.
Cincinnati Rick is offline
Old March 7th, 2023, 10:47 AM
  #903
Moving along I got some lead free body solder tinning butter and paddle wax from Eastwood , I bought three tubes which really wasn’t enough so I bought a couple more stuff is pricey.
I tinned the seamsand applied the solder , easy enough, and there’s tons of videos and how tos on you tube
Old March 7th, 2023, 10:50 AM
  #904
The nice part is you can hammer and dolly , and it really sticks , I did go back and add solder , and the plan now is to prime and apply first a skim of duraglass just in case and then regular putty as required , it won’t take much of either
feels great to be back in the saddle
Old March 7th, 2023, 10:57 AM
  #905
VI Cutty's Avatar
Looks great! Taking the time to do it right will pay dividends down the road.
VI Cutty is offline
Old March 7th, 2023, 11:05 AM
  #906
alain's Avatar
Hi Eddie
It is looking great now you are having real fun
I won't be far behind you.
Alain red W-31
alain is offline
Old March 7th, 2023, 11:25 AM
  #907
maddoctor's Avatar
Very nice work. The solder is sure to keep the seam sealed for a long long time. 👌 Glad all is good. Soon it will be time to get outside for a couple of frosty mugs. Hopefully, we can meet up this summer I can bring some Canadian-type brew and you can bring some USA type brew and we can mix and match them.
Take care.
Old March 7th, 2023, 11:53 AM
  #908
Thanks fellas
I tend to over think and that leads to lulls in progress , appreciate the support and kind words it does keep me going!!
anyway moving along I also took the opportunity to adjust the door gaps I don’t know if it’s just my car or something on the 69’s but it seemed impossible to get and even gap from top to bottom ? My car it seemed that the gap on the top curve was wider then the straight part of the gap? I adjusted for hours on the replacement door and got it where it was “ok” but I wasn’t thrilled , it was the exact same on the original doors both sides
I was thinking to take 1/8 steel rod and mig weld and grind it , but while I was doing the leading , I closed the gap, now from top to bottom it’s exactly a paint stick thickness gap , took awhile but I’m happy with the results , I want to finish the metal the best I can prior to any filler , I continue to hammer and dolly and a few areas required a shrinking disc which also worked great
Drivers side
Drivers side
Passenger side
Old March 8th, 2023, 06:56 AM
  #909
BackInTheGame's Avatar
Fantastic work!
BackInTheGame is offline
Old March 8th, 2023, 09:23 AM
  #910
scrappie's Avatar
Looking good. You’ll be glad you spent the time at this stage when it comes time to block sand.
scrappie is offline
Old March 8th, 2023, 10:52 AM
  #911
Thank you fellas
Yes I’m sure blocking will be much easier !! But not quite there yet , when I get tired of sanding grinding etc I go to opposite side and hammer and dolly or shrink or whatever , there is the issue of the convertible stiffness that prevent access to the back side so it is what it is in that area not terrible but I would love to get behind that panel , lol
the plan for the trunk is epoxy primer and then epoxy truck bed coating , I’ll be using this for the rear wheel wells as well ,
I can then decide after to go with an original style spatter paint But durability is a concern? I wonder if anyone makes this style paint that isn’t water based?
Old March 8th, 2023, 11:03 AM
  #912
I was thinking to go with the u pol brand raptor , ? I believe I have read here several folks have used it I do plan on driving the car not showing it so it makes sense to me lol I am up for any other suggested products
Old March 8th, 2023, 12:03 PM
  #913
Moving along
Well I’m sure by now everyone knows I’ll be finishing the car like a 69 hurst olds convertible, I ordered the mirrors , scoop and spoiler from fusicks, I reading through the forums I read that the hurst olds style mirrors need to be mounted as far forward as feasible to maximize their usefulness , well passenger side is no issue as there are no predrilled holes for a remote mirror, drivers side not do much , so I made some sheet metal plugs by bending some 20 gauge sheet to the right contour , slipping it under the area and tracing the hole shape, I held this in place with a magnet at first , and this played havoc with the tig , I managed to get a couple tacks and removed the magnets , I then tapped it down and filled with the body solder , seems fine for me lol and I’ll be able to move the mirrors up a couple of inches
Old March 8th, 2023, 12:11 PM
  #914
Home made tools
I found I needed a smaller hammer to fit in around obstructions and such , plus some new flapper files, I’m kinda cheap lol so I made some tools from crap I had laying around
Cheap body homemade
El cheap o next to my uptown hammer lol
Some home made slappers made from files and such
Some smaller dollies made from a larger combo dolly
And another home made hammer for really tight places
Old March 10th, 2023, 05:07 AM
  #915
chopolds's Avatar
Good job on the soldering, the lead free stuff is harder to work with, than the real lead! BTW, you can get lead, and lead free, a lot cheaper at Roto Metals, or Johnson manufacturing. As for the sub for those spatter paints that can wash off: I've been using Zolatone. It's an architectural paint, that is really tough, and looks similar to the original spatter paints. Comes in a variety of color combos. When I restored a 69 Buick GS, I was able to use 2 color combos, to get a good match to what was there originally.
Keep playing with that TIG, you'll get better and better with your metalwork!
chopolds is offline
Old March 10th, 2023, 08:17 AM
  #916
Thank you for the kind words !! High praise indeed coming from a master like yourself! , also thanks for the paint tip and alternate source for supplies Eastwood gets 65 bucks for 4 measly sticks and they don’t go very far , I do feel very comfortable now after the body solder that it will be a quality job , and the hammer and dolly work wasn’t too bad , I’m also learning to use a shrinking disc, plan is to really minimize filler but there’s going to be some I am not good enough to have buffed steel lol,
any tips for areas you can not get to the back side? I could cut the inner bracing but I’d be very uncomfortable doing it and don’t really think it’s worth it I’ll have to live with putty in that area ( about 8-10 inches of seam)
Well back to the shop
Old March 11th, 2023, 05:56 AM
  #917
chopolds's Avatar
Eastwood does have lots of hard to find stuff in one place, but it's always less expensive to buy it elsewhere, if you can find what you need.
I never have an issue cutting out the backside of a panel to make the visible side better! You don't see the backside, most often, so it doesn't matter, much.
You can sometimes get away with using the dolly with a handle, where you can't get directly behind the seam.
Amazon.com: Martin 1052 Spoon Dolly, 2 1/2 " x 1 " x 3 ", 4 pounds : Industrial & Scientific Amazon.com: Martin 1052 Spoon Dolly, 2 1/2 " x 1 " x 3 ", 4 pounds : Industrial & Scientific
chopolds is offline
Old March 11th, 2023, 07:10 AM
  #918
Thank you for the tool tip ! I like Martin body tools , heck I like tools period lol, I’ll wait till my next project as I work on my skills lol before cutting the brace I do appreciate all your sound advice !
Old March 30th, 2023, 07:48 AM
  #919
Moving along
As a quick update as I continue tidying up the body , finishing little odds and ends I kept thinking I need more cfm, I posted a thread for compressor suggestions and I decided to buy the emax 80 gallon silent air it delivers 31 cfm @ 100 psi and 26 @ 175 ( I’ll never use that pressure) well it arrived yesterday , I am putting it in my shed to make working in the garage a little more pleasant , I plumbed air line from shed to garage previously in anticipation.
well wtf was I thinking lol
it comes in a big azz box
Old March 30th, 2023, 07:55 AM
  #920
Seriously it looks like a great machine pricey but looks like I won’t be waiting for tank pressure anymore it has continuous mode and the pump ( Eaton) looks like serious but of kit , as a heads up for anyone it wasn’t the easiest thing to move you will need a little help , I managed it but I wish I did this when I was a bit younger lol
Quick Reply: Eddie Hansen's '69 Cutlass Convertible
